Failure rate?
Old Nov 16, 2003 | 03:15 PM
Jlower's Avatar
Jlower
Failure rate?
Yesterday when I put my truck up on the rack I noticed a couple distubing finds.
1. I have a slow leak from my front seal.
2. My differential has a slow leak as well. It took 2 quarts of gear oil to get it up to the plug level!
My question is this: With the truck being an 03 at 37K has anyone else run into these problems so early into it's life?
Old Nov 16, 2003 | 06:58 PM
flynavydiesel's Avatar
flynavydiesel
Ya know, I noticed the same thing about my front seal:confused. I noticed oil on the steering linkage. Wiped it clean and fortunately I not seen it again. But that was only 2,000 miles ago that I found it.
I also had just switched to synthetic, so maybe that was it. No clue. I am keeping an eye on it.
Sean:
Old Nov 17, 2003 | 10:53 AM
HoseDog's Avatar
HoseDog
I had to replace the rear pinion seal at about 30K - Never did figure out why it failed.
