Sponsored by: Kumho
camber problems??????
Old Nov 16, 2003 | 12:27 PM
95f150's Avatar
95f150
Hello,
Im currently having problems with my 95 f150. I have negitive camber, about 3 degrees on each side. Tires look like / \ . They used to be out around 5 degrees each. I have a 4" suspension lift and a 3" body lift. Currently running 35 x 14.50 x 15. They were around 5 degrees on either side until i brought it to the shop. They used shims that helped a bit, but now my alignment is out.(steers to the right bad!)They tell me i need new coil springs. Does anyone agree? If it helps my frame was twisted slightly by the passengers side radius arm, im not to sure how out they were before i bent the frame cause i only had the truck for 6 months. The lift has been on there for at least 3 years that i know of. Specs say my camber should be 0.25" on either side. I want to buy new tires but i will have bad tire wear.
A few other things my truck comes stock with 3.55's is that still okay for 35" tires. My power plant is only a 302. Im not sure if its stock gears in their, this is what i got off the diff tag
S83 8J
55 88 5E25
Its a 10 bolt design. Dana 44 (open Diff)
ANY IDEAS?
Trying to figure info on manual tranny aswell.It says
F1TA
GC
C110535
WHAT DOES THIS MEAN?
Old Nov 20, 2003 | 12:02 AM
stRanger706's Avatar
stRanger706
geez...ford and their camber issues....ok if the shop put new shims in and that helped but didnt fix the problem completely, then your springs are probably sagging pretty bad. the suspension on your truck articulates like this ( ) so if your springs are sagging, your wheels will be stuck like / \ , just like you said. some aftermarket springs sag with age, some dont, depends on the brand. so all in all, you need new springs to level your truck out and let the suspension sit neutral at 0 degrees. as for the frame damage, that could mess all sorts of things up, i have no idea what you'll run into with that. hell it may not affect it at all. does this help
venturasurf
1978 - 1996 Big Bronco
Mar 28, 2013 09:22 PM
95f150
May 13, 2005 08:41 PM
95f150
Offroad & 4x4
Jun 19, 2004 08:26 AM
95f150
Jan 11, 2004 06:32 PM
95f150
Nov 15, 2003 11:14 AM
