How do I get the limiter disabled?
Old Nov 16, 2003 | 10:43 AM
larrys3d's Avatar
larrys3d
Unhappy How do I get the limiter disabled?
Here is my problem...
I AM in Germany, and my new Ranger just arrived...and yup, I hit 90 mph, and the silly thing starts cutting out.
Now, here in Germany, 130 km, or 90 mph, is about the same as doing 55 in the fast lane on the highway in the US. Pitiful showing for an American made vehicle.
Any way to have Ford hop up the speed limit, or is there another option?
Larry
2004 Ranger Edge 4x4
4.0L
Extended Cab
Automatic Transmission.
Old Nov 16, 2003 | 12:13 PM
Rand's Avatar
Rand
Your limiter is there for a reason.
Your 4x4 tires would be dangerous above that speed.
Also your high profile narrow truck has bad handling.
If you still feel the need to kill yourself
You can disable the limiter with a chip.
I would suggest at the least a Shock upgrade to something like edelbrock performer IAS, and a tire upgrade to something thats higher speed rated.
Rand
Old Nov 16, 2003 | 12:58 PM
larrys3d's Avatar
larrys3d
Thanks. The speed rating on the tires is 112 MPH now, and was wondering why the chock upgrade?
Looking at the chip upgrade too. Like I said, Autobahn speeds are a bit different
Old Nov 16, 2003 | 02:21 PM
Rand's Avatar
Rand
The stock shocks blow. Just wait till you have about 15000 on them.
Old Nov 17, 2003 | 02:01 PM
larrys3d's Avatar
larrys3d
Thanks for the warning on the shocks...will look into new shocks here on the economy......
Thanks for the tire info, too....just chased down some T rated tires withan agressive tread pattern. I only need to speed on the open road, not gonna do that crap in this mountainous stuff here....
Old Nov 17, 2003 | 04:57 PM
Rand's Avatar
Rand
Personally if I was going to go 90 daily I would be looking for bigger rims and at least H rated tires. You could run your stock stuff in the winter...
The better the speed rating.. basically the better the tire handles at higher speeds.. less ballooning(sp?) etc.
Not much difference between S and T
Although if your tires were worn out.. obiviously T is a bit better
