new fuse panel location
Old Nov 16, 2003 | 09:25 AM
64fordf100's Avatar
64fordf100
Question new fuse panel location
Due to an unfortunate ignition switch mishap, the yellow wire to the starter solenoid self destructed from switch to the splice beneath the dash. The switch (aftermarket) appeared to default to the start mode with starter engaged/truck running and would not cut truck off which I did at the battery. Upon switch removal it fell apart. I just received a new harness from Centech which seems straight forward. My problem lies in where to mount the new fuse panel. There doesn't seem to be a good location beneath the 64 f-100 dash without fabricating some type of mounting plate. Has anyone done this?
