6.7 Engine Temperature
Old Mar 10, 2023 | 12:46 PM
Reedog's Avatar
Reedog
Just installed an 8" cluster in my truck. Previously had a 4" display. So, now I'm able to see coolant temperature numerically above the guage. Running around town it's only arount 175°. I expected it to be over 200°. Is this what you guys are seeing unloaded on your trucks?
2022 F-350 XLT 6.7
Old Mar 10, 2023 | 01:06 PM
4wd6.7L's Avatar
4wd6.7L
Coolant temp or oil temp? Also, what is the outside temperature. Normal operating coolant temperature as shown on my dash is about 192-196. I don't often watch the oil temp, but when I have it seems to trail behind the coolant temp till it catches up to about the same. Takes several miles of driving to get there (50's-60's ambient).
Old Mar 10, 2023 | 01:15 PM
Reedog's Avatar
Reedog
Coolant temperature. About 50° outside. 175° seems low.
Old Mar 10, 2023 | 01:23 PM
4wd6.7L's Avatar
4wd6.7L
It does seem low unless it just isn't given the drive time to reach operating temp. Empty, low speed surface street driving, mine takes a good 10 miles of driving to get there.
Old Mar 10, 2023 | 01:35 PM
Gomerpyle's Avatar
Gomerpyle
Mine runs right about 196 when fully warmed up. It'll get up to 205 then thermostat opens & it drops to 192, then levels off at 196.
Old Mar 10, 2023 | 01:56 PM
senix's Avatar
senix
I just drove from maryland to arizona with ambient temps in the 50-60 range.
Coolant temp hovered around 180.
this was unloaded run.
the cooling straegy is different 2020 and up.
Old Mar 11, 2023 | 06:52 AM
HeavyAssault's Avatar
HeavyAssault
I'd double check those temps.
Old Mar 11, 2023 | 11:26 AM
Killer Volt's Avatar
Killer Volt
2022 F-350 XLT 6.7
I also upgraded to a 8" cluster and added gauge temps to my 2017 F350 6.7, mine runs at 192 and the transmission is always190. I live in a cold climate and it can take 10+ mile to get up to operating temp.
Old Mar 11, 2023 | 06:50 PM
Reedog's Avatar
Reedog
Photos taken on the freeway after 40 minutes of driving. It won't go over 181° and sometimes goes as low as 166°. The temperature fluxuates widely depending on engine load so the poppet must be partially open and not moving. The thermostat is supposed to begin opening at 194°. I wouldn't ever have known this without an actual temperature number. Wonder if it's been like this since new?
Old Mar 12, 2023 | 08:50 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Mine seems to run at 189F at operating temp when running around unloaded. Loaded it can get over 200F. Pulling our camper to Chattanooga, TN a couple days ago I saw it get up to 206F on one longer climb, but otherwise it stays below 200F. Now when summer time temps gets here it may go a little higher.
Old Mar 12, 2023 | 10:09 AM
Painted Horse's Avatar
Painted Horse
You should see temps around 194° when your truck is warmed up
Old May 5, 2026 | 01:47 AM
JT Red's Avatar
JT Red
Maybe some one put the low temp high flow aftermarket thermostat in it. Seems to me they run around 170
Old May 5, 2026 | 02:01 AM
Reedog's Avatar
Reedog
I put in a new Motorcraft thermostat and that brought the temperature up to around 190. Apparently the old thermostat was allowing flow at a lower temperature.
Old May 5, 2026 | 07:49 AM
gsxr1216's Avatar
gsxr1216
Mine runs 183-186 on the banks Idash unloaded. it will go to low 190's as the truck comes to temp then once the tstat opens all the way it bounces in the low 180's. towing it will run more in the mid 190's range
Old May 5, 2026 | 09:12 AM
senix's Avatar
senix
I watch the oil temps as the best method of heat production when oil temps are around 220F then coolant starts to rise.
