93 f150 5.8 terrible mpg?!?
Mar 9, 2023 | 05:54 PM
Quote:
Originally Posted by
R&RFord
That is a crazy thought.
I look forward to seeing another low mileage truck on the market soon.
I just got my truck in September. I am not planning on selling any time soon.
Mar 10, 2023 | 10:15 AM
OBS4ever
I Believe the spark plug wires and the coil wires are original because of only 103000 miles.
If they are original wires they should have a production year printed on them. If so they are likely due for a replacement after 30 years
Mar 10, 2023 | 10:43 AM
McLeod
Like this? Haha got 318ish thousand miles out of them.
Mar 10, 2023 | 11:05 AM
Yes, I just replaced my 1995 wires just last year myself, albeit with less than 200k miles on them.
Time makes them brittle and susceptible to deterioration.
Lasted a good long time though.
Mar 10, 2023 | 07:05 PM
Im looking forward to the conclusion of this thread.
Mar 11, 2023 | 08:42 AM
Something no one has mentioned is your poor MPG could be fuel transfer between tanks & they almost all do it.
Mar 11, 2023 | 10:55 AM
Scndsin
When I had checked my gas mileage. I had filled both tanks and used combined mileage on both to check my gas mileage. The result was 7.5 for both tanks.
Mar 11, 2023 | 11:55 AM
OBS4ever
right but if you have two full tanks, and one is filling the other... the inactive full tank will spill out going down the road because you can't put 20 gallons in a 19 gallon tank. So you are losing fuel and it isnt even going through the engine.
Mar 11, 2023 | 11:56 AM
How does the truck actually run? Smooth and adequate power? Or lacking power and rough running?
Mar 11, 2023 | 03:51 PM
Mudsport96
It runs smoothly and has adequate power, it does start rough when warm though.
Mar 11, 2023 | 03:55 PM
OBS4ever
and you checked the intske air temperature sensor right?
Mar 11, 2023 | 04:03 PM
Mudsport96
I am about to check them today.
Mar 11, 2023 | 05:18 PM
OBS4ever
After pulling and cleaning both sensors. The truck started quicker and It idles smoother than It had been.
Mar 11, 2023 | 06:34 PM
OBS4ever
Which sensors did you clean? IAT and which other one?
Mar 11, 2023 | 07:40 PM
Prototypemech
Act and Ect, I cleaned with brake cleaner.
