Tongue weight?
Thank you btw.
I've also used the CAT Scale to get the various weights that @seventyseven250 listed. I think it was $15. I used the app on my phone. Easy peasy.
Also, the app is very easy to use. Setup a profile and assign a payment option, then drive up to the scales, make sure your axles are on the appropriate separate scales, enter the number at the scales and wait. After the payment is submitted you will get a screen like this:
If you weigh in the order mentioned above starting with the truck only, your first ticket will have 00 lbs for trailer axle. Then just drive off the scales, drop the trailer hitch on the ball and drive back over the scales. Finally, connect your WD bars and drive over again for your third weight. After this, if you need to put more weight back to the trucks front axle, just tighten the bars more. If you want to confirm, drive back over the scales for another few bucks.
Also, IMO, it’s good to do this often, not just once. As you add/remove stuff, or just load your camper differently, the weights can change. It’s also important to drive over the scales with everything you are planning to carry, including passengers and a full tank of fuel, and even full propane tanks. The good thing is once you go over the scales the first time with just your truck, you will know the weight of your front axle, and this is my reference point. For future trips I just go over the scales once with the WDH engaged, and then I can make WD adjustments based on the weight of my front axle.
To simply find the trailers tongue weight, just find the difference between the trucks unloaded rear axle weight and the weight of the rear axle with the trailers hitch sitting on the ball and no WD applied.
to get the tongue weight you need the axle weights both loaded and unloaded.
you need to add the front and rear axles of the unloaded vehicle to get the total weight of the unloaded vehicle. then you need to add the front and rear axles of the loaded vehicle to get the total weight of the loaded vehicle.
then subtract the total weight of the unloaded vehicle from the total weight of the loaded vehicle.
just looking at the rear axle weights will give you an incorrect answer.
example (from my weight tickets)
unloaded:
F=3160, R=3180
loaded:
F=2580, R=4960
just looking at the rear axle weights, you would come up with a tongue weight of 1780lbs. This is incorrect because there is 580 lbs moving from the front axle to the rear axle.
if you sum the unloaded weights, you get a total unloaded weight of 6340
if you sum loaded weights, you get a total loaded weight of 7540.
The true tongue weight is 7540-6340=1200 lbs
unloaded:
F=3160, R=3180
loaded:
F=2580, R=4960
Like I mentioned above, to find the tongue weight, simply find the difference between the trucks unloaded rear axle weight and the weight of the rear axle with the trailers hitch sitting on the ball and no WD applied. This is easy to do, just drive across the scales with your empty truck, then just drop the trailer on your hitch and drive back across. Now, find the difference in the rear axle numbers and this is your tongue weight.
Correct me if I am wrong, but what you described is how to get the tongue weight AFTER you set the WDH since the WDH will shift weight back to the front axle. Just dropping the trailer on the hitch without any weight distribution set will unload the front axle. (Of course this is for a bumper pull.)
You could also come over to my house and borrow my tongue scale.
that’s why the method above is recommended.
