Engine will not roll over
Old Mar 7, 2023 | 05:31 PM
Tooters's Avatar
Tooters
2nd Gear
2019 F250, Gas 6.2, 15k miles. Put key in and roll over to start. Nothing. No clicks, just nothing. Take key out and try again, nothing. Take key out and try again and strong roll over and starts. It don’t happen every time but at least once a week. Installed a new battery, same problem. All the normal bells go off when I install the key. Does it have a starter relay somewhere other than the starter solenoid? I hate intermittent problems.
Old Mar 7, 2023 | 05:46 PM
OverheadCram's Avatar
OverheadCram
It wont roll over, but it sure plays dead!
In the meantime until it does it again, id start with checking the starter connections. Back them off and then reseat and snug them up. Next time this actually happens turn the key over and no crank, see if with the key still turned over and your foot on the brake you can shift to neutral and start the truck. There are other things to check with a voltmeter when its actively happening, but until then I wont send you on a wild goose chase to most likely find nothing because its starting up normal.
Old Mar 7, 2023 | 06:12 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Mine does this every once in a while. Turn the key...nothing. Let off, turn the key again and it starts normal.
I ain't too worried about it...
Old Mar 7, 2023 | 06:44 PM
senix's Avatar
senix
might be an ignition thing.
Old Mar 8, 2023 | 07:29 AM
speedfreak78's Avatar
speedfreak78
Sounds like a ignition switch or starter going bad or a bad electrical connection in the starting circuit. First thing to do is get a comprehensive scanner hooked up to it and see if it's throwing any fault codes. If that doesn't show anything, I'd start at the battery and pull all the cables on both ends, clean and coat them in dielectric grease and do the same thing to any wires and plugs in the starting circuit. You could pull the starter and get it tested, but where it's intermittent it might test OK. This sounds like one of those issues you either throw parts at, or wait for a total part failure to single it out.
Old Mar 8, 2023 | 07:55 AM
shawnee1's Avatar
shawnee1
When you turn the key to the start position you are not directly engaging the starting circuit. You are sending a signal to one of many control modules telling it that you want to start the engine. The control module engages the starting circuit. But first!, the control module checks several things including communication with other modules. If it doesn't get the right responses is does not engage the starter circuit. An important diagnostic step is to check for any error codes that may indicate a bad control module and/or communication path.
Old Mar 8, 2023 | 08:28 AM
4wheelsandahitch's Avatar
4wheelsandahitch
I hate these intermittent issues.
Old Mar 9, 2023 | 10:50 AM
RedNNBlue's Avatar
RedNNBlue
Just spitballing an idea
I have no experience with this particular problem, but could it be as simple as the chip in the key not communicating?
Old Mar 9, 2023 | 12:16 PM
redford's Avatar
redford
FTE Leadership Emeritus
Maybe the neutral safety switch? Try shifting to N instead of P.
Old Mar 9, 2023 | 05:39 PM
4wheelsandahitch
Will these new trucks start with the transmission in Neutral?
SenorSneu
6.7L Power Stroke Diesel
May 15, 2021 03:11 PM
Raider50
Jul 7, 2014 08:42 AM
70T351W
Jun 4, 2008 08:17 PM
UPSTATE MARK
13
Aug 19, 2007 03:07 PM
transvan
Jun 22, 2004 09:17 PM
