Banks Pedal Monster
Old Mar 16, 2023 | 01:27 PM
  #76
aklim's Avatar
aklim
Originally Posted by GAZZILLA
Given the choice I’d rather not have something permanently plugged into and wires sticking out of the OBD2 port.
If you have any warranty, that might not be a choice if you want to do something about the tip in.
Old Mar 16, 2023 | 01:31 PM
  #77
GAZZILLA's Avatar
GAZZILLA
Warranty isn’t an issue my throttle controller is easily removed.
Old Mar 16, 2023 | 03:16 PM
  #78
jimzpsd's Avatar
jimzpsd
The plug that comes with the Banks is a right angle type, so it sticks out (maybe) an 1/8" beyond the open port. No way will it interfere with anything for me.
Old Mar 16, 2023 | 03:19 PM
  #79
aklim's Avatar
aklim
Warranty does not allow tuning.
Old Mar 16, 2023 | 03:22 PM
  #80
ToMang07's Avatar
ToMang07
Well good thing it's not a tuner then, isn't it?
Old Mar 16, 2023 | 03:24 PM
  #81
aklim's Avatar
aklim
That is what I mean. If you have any warranty, you have to settle for a bolt on that is removable
Old Mar 16, 2023 | 04:45 PM
  #82
jimzpsd's Avatar
jimzpsd
I do not have a warranty any longer and I didn't "settle" for the throttle controller. The way I look at it, these trucks have TONS of horse power in stock format, and I don't need more, however these throttle controllers really help deliver the power sooner without going wide open. My wife's 2020 Honda Pilot has a push button on the dash for economy mode, turn it off and it comes alive...almost like a throttle controller is what I would describe it as. It truly is an experience one must feel while driving. Yesterday I put it in "track mode" #10 and from a stop I smoked the back tires (35's), never did that before with this truck, I have it in city mode #5 and I'm real happy with this setting.
Old Mar 16, 2023 | 08:20 PM
  #83
aklim's Avatar
aklim
So would a tuner, from what I am hearing. Also, while it can give a little more power and efficiency, if that is no interest to you, fair enough. In the 7.3 diesel, it was able to change the shifting strategy and points between towing, race and street. If this extends to these trucks, I'd have to say that I experienced what you are talking about. With being able to change the tip in and shift strategy and points, just doing the tip in, kinda feels like settling. If only we could change on the fly. That would be the cherry on the sundae.
Old Mar 16, 2023 | 08:56 PM
  #84
jimzpsd's Avatar
jimzpsd
My '97 7.3 had the Banks goodies back in the day, Swamps injectors, Tymar cai, etc, it was fun but compared to my '17, it wasn't even close. These newer diesels are insane stock, and now with a throttle control it is alive the entire power band...without a tune and a mere cost of $262, plug and play.
Old Mar 18, 2023 | 03:29 PM
  #85
acdii's Avatar
acdii
Where's Waldo
If you kick it, you would be kicking the dashboard, or kicking the port all the time.
Can barely even see it. Making such a big deal over nothing.
Old Mar 18, 2023 | 05:41 PM
  #86
aklim's Avatar
aklim
Originally Posted by acdii
Where's Waldo
I did the AFM dongle my C7. Didn't want to try it here since I will probably risk a tuner and have more say over the truck that a dongle that is a "one trick pony" which was my complaint on the C7.
Old Jul 20, 2023 | 08:26 AM
  #87
ThirdsACharm's Avatar
ThirdsACharm
Hi - also going to reach out to Banks support today - but anyone else getting faults on their Banks Pedal Monster?
The Code is: 1.2: APP2 Input Voltage Out of Range.
You need to unplug from the OBD2 and it will reset. But the next time I shut the truck off, it goes to a fault.
I recalibrated the pedal - that didnt help either.
Wondering if its related to firmware vs a software update on the truck....
Old Jul 20, 2023 | 08:49 AM
  #88
jimzpsd's Avatar
jimzpsd
All I can offer at this point is to verify your iDash has the latest firmware, thats probably going to be the first thing they will ask you. Also you can plug an OBD2 code reader into your truck to make sure it is communicating properly from the port.
Old Jul 20, 2023 | 09:53 AM
  #89
redford's Avatar
redford
FTE Leadership Emeritus
Give Banks a call. They have great customer support.
Old Jul 20, 2023 | 10:20 AM
  #90
ThirdsACharm
Update: I called customer support - they're sending a replacement.
