I know this subject is almost exhausted but I reprogrammed mine on trailer mode (just to be safe, 3500lbs 24ft enclosed and 11k mls in 16 days) and I LOVE IT.
The only question I have is:
After a couple of hours driving I shut off the engine and it was +/-16degrees. After 2 hours when I started back up it sounded as if the pressure valve of the turbo stayed open. A lot of hissing sounds and no power.
This happend 2x and every time it was freezing pretty hard.
Does this happen more or do I need to have it fixed?? (it works fine as soon everything is heated up and here in Florida it does noet have the same problem).
