Sponsored by: Real Truck
Turn signal issues
Old Mar 5, 2023 | 09:38 PM
chrs2ca's Avatar
chrs2ca
4wd High
Turn signal issues
The front passenger turn signal bulb on my 2012 f250 stays on "high" all of the time and does not flash when the parking lights are on. I tried replacing the bulb (led) but the issue remains. It is not a flasher issue because all of the other bulbs flash correctly. Any ideas on what to check next?
Old Mar 6, 2023 | 02:13 AM
marksman76's Avatar
marksman76
Check and clean all wiring connections and bulb socket.
Check the ground wire.
Sometimes ground wires do other things, as in trigger items.
Old Mar 13, 2023 | 03:19 PM
Catch This's Avatar
Catch This
what marksman said....and double check the ground
Old Mar 14, 2023 | 06:51 PM
chrs2ca's Avatar
chrs2ca
4wd High
Thanks, after checking everything and not finding any issues, I purchased new bulbs... again. Apparently the last pair of new bulbs I picked up was defective.
lfry
Sep 4, 2022 07:30 PM
questie760
Aug 19, 2022 07:55 PM
jv106
May 31, 2022 12:20 PM
03_superduty
Dec 6, 2011 01:20 PM
deficientblair
2004 - 2008 F150
Dec 19, 2009 01:07 AM
