I think with modern synthetics oils the sludge is not an issue anymore. Lots of ‘always done it this way’ but as long as you change it warm/hot I don’t think you’d see much difference. I’m remembering the Banks video with the clear cover, there’s no way anything is building up down there the way that ring gear slings oil.
Who drops their oil pan to check for sludge in the engine, and that is far more critical.
And you'd be wrong, because there certainly IS sludge build-up in the bottom of a differential. I changed mine at 25k miles and there was enough in there already to tell.
Transmission pans are dropped and cleaned out as standard procedure. Most don't have drain plugs.
Engine oil pans WOULD be dropped and cleaned out more if they were easy to get to. 9 times out of 10, there is just way too much stuff in the way to make that possible...crossmembers, axles, trans bellhousing, etc. I've had enough engines out with the oil pan off to know that there is always buildup in the bottom of them (and sometimes other things that will make you scratch your head).
Pull the cover and clean. If you want to really get as much fluid out as possible, use a jack to alternately raise each side to drain the axle shaft.
Originally Posted by Ltngdrvr
I always pulled the covers, but it is most important that you just get the lube refreshed however you do it.
On my previous RAM, the rear diff had a really great reusable cover gasket, rubber with a metal core, had the cover off and on many times and never had to replace the gasket.
Like I said, do it however works easiest for you.
Same experience with my 3rd gen Ram. Excellent reusable gasket which made it a snap to do a fluid change. Using RTV to seal a power train component is ludicrous in this day and age. Drain plugs would be helpful too.
get a 6 pack of beer, a lawnchair, a grandson, and teach him what to do. pull the diff covers. you prolly wanna pull the trans pan as well if its the first time being serviced. thats a few hours of being on the floor wrenching and messing with fluid.
One step at a time, we're working on this method. And he can probably work on it without my needing to lift the truck off the ground...
I do enough water crossings in my Wranglers that I’ve changed diff fluid more often than would otherwise seem normal. Despite raised vent hoses, I just can’t take chances.
I was surprised to find that the Dana 44s on my 2012 JK Wrangler - unlike the Dana 44s on my previous 2004 TJ Wrangler - actually have a second drain valve under the pumpkin. It was hidden well enough that I didn’t see it until the first time I dropped the cover. I’ve drained it through this port since, always looking for evidence of water in the dif.
I bring this up because I find it hard to believe that Ford hasn’t required similar changes on their newer axles. It would make normal changes much easier, and allow more oil and grit to drain than vacuuming.
The M275 has a drain incorporated. You just need to pull the right side (passenger side) bolt at the bottom of the pumpkin. No need to pull the whole cover off.
