Bronco II Ford Bronco II
bronco just quits!
Old Nov 15, 2003 | 06:25 PM
promad's Avatar
promad
bronco just quits!
hi i need help fast , my wife has a 88 bronco 2 with the 2.9 fuel inj . that the she uses for a mail truck that i got to get fixed quick!! , going down the road it does fine then all of a sudden it starts jumping and sputtering and goes dead right in the middle of the road , but it don't go dead everytime , sometimes it will crank right back up and then sometimes up to 10 to 15 minutes before it will crank , i need help fast and quick , can anybody help me ?
thanks lee
Old Nov 15, 2003 | 07:34 PM
promad's Avatar
promad
Re: bronco just quits!
thanks lee
oh yea and when it does this it smell like old gas kinda like varnish , its wierd !!!
thanks lee
Old Nov 15, 2003 | 09:55 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Do you have black smoke when it starts back up?
The most common cause of stopping on the road is the TFI module, my 1988 5.0 HO Mustang LX FB did that to me a few times.
Old Nov 16, 2003 | 12:06 AM
pozner's Avatar
pozner
I can only go with the obvious. Fuel filter, TFI, TPS?, air filter. Then into speculation; vacuume operated fuel pump relay, cracked distributor cap? Not sure about the old gas/varnish smell, since I'm sure it isn't old gas, is it?
Old Nov 16, 2003 | 06:21 AM
promad's Avatar
promad
thanks ken and pozner , no it isn't old gas and i don't know about the black smoke but i will drive it and look and see ,the tfi module what exactly is that , were is it located , is it something i can change easily ?
thanks lee
Old Nov 16, 2003 | 09:41 AM
Msloke's Avatar
Msloke
My 87 BII was doing the same thing. Replaced the TFI and still would die. Had the stator replaced and hasn't died since (about two months ago). Ford dealer said they replace the stator when replacing TFI, if stator is worn it can send confusing signals to TFI and engine will quit. You might want to consider changing the stator too.
Old Nov 16, 2003 | 01:45 PM
WeWonIt's Avatar
WeWonIt
I'll throw my suggestion out to you, for what it is worth. Mine would do the same thing, including smelling like old gas, "lean condition". Do you have fuel at the intake when this happens? If not you might have the same problem I had, either a faulty connection at the external fuel pump or a bad fuel pump. I tried everything, replaced everything and was about to give up when I realized the obvious had escaped me, after a quick check of the fuel cert on the intake I realized I had no fuel pressure. And the condition was non consistant because it was a bad connection. a new connector later and no further problems.
