Sponsored by: Real Truck
Heavy coolant loss PLEASE HELP
Old Feb 25, 2023 | 09:39 AM
ClarkeH's Avatar
ClarkeH
3rd Gear
I have a 2004 ford f250 6.0 powerstoke, it has 219,000 miles and everything is original and the emissions equipment is still installed. I have a coolant loss. I have to put in a gallon of coolant every week and a half. There is no coolant present in the oil, it has no coolant leaks, and it is used as my work pickup and a drive everyday for long trips. It runs flawlessly but I know it’s has abnormal coolant loss, if anyone has any idea please let me know
Old Feb 25, 2023 | 10:32 AM
m-chan68's Avatar
m-chan68
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Feb 25, 2023 | 08:24 PM
PJWhelan's Avatar
PJWhelan
I have a 5.4L 2002 F-250 (228,000 miles) with original engine too. My coolant loss is a diagnosed Head Gasket issue. I had a heavier loss in the cross over tube which is mounted to the Air Intake manifold. I changed that out and loss of coolant is significantly less but the Head Gasket still needs a fixin'. Check your tailpipe for that unmistakable sweet coolant smell.
Old Feb 27, 2023 | 01:20 PM
Edd505's Avatar
Edd505
EGR coolant is a common leak on the 6.0, look for white smoke at the tail pipe, check the inter cooler for coolant, if present it needs replaced, also check water pump for leaks.
ryanrk12
6.7L Power Stroke Diesel
Jul 30, 2019 12:33 PM
Anthony Giovino
Ford Truck Parts for Sale
Apr 15, 2017 07:55 AM
fski50
Apr 26, 2015 08:28 PM
ford390gashog
Jun 4, 2004 09:56 PM
