Which Rear Axle?
Old Dec 5, 2002 | 02:30 PM
teamjlp's Avatar
teamjlp
Which Rear Axle?
Old Dec 31, 2002 | 01:34 PM
3992824's Avatar
3992824
Which Rear Axle?
Anyone know what rear axle is used in a 2000 Ford Excursion 2wd V10?
I think it's either a Ford 10.5" or a Dana 80. The illustration in the CD manual I've got isn't clear enough to see, although from the back, it looks like the picture of the Dana.
I saw a post awhile back by a guy that said he swapped a 3.73 for a 4.10 in his truck (thought it was a superduty?) because a 4.30 wouldn't fit? Would one of these fit that description?
Thanks
(I posted this over in the drivetrain forum without reply. Shoulda given you guys first crack!
Old Dec 31, 2002 | 03:41 PM
DCSpecial's Avatar
DCSpecial
Which Rear Axle?
The Dana 80 is only used on F-350 & F-450 DRW trucks. I think the X has the same rear as the SRW SDs which is the Sterling 10.5".
As for the gears 4.30 are available for both the Dana and the Sterling.
Hope this helps
Old Dec 31, 2002 | 11:40 PM
rikosintie's Avatar
rikosintie
Which Rear Axle?
DCSpecial;
Out of curiosity, do you know how much it would cost to swap 3.73 gears for 4.30? Thanks.
Michael
Old Dec 31, 2002 | 11:53 PM
DCSpecial's Avatar
DCSpecial
Which Rear Axle?
[updated:LAST EDITED ON 01-Jan-03 AT 00:55 AM (EST)]It's around $325 per in parts per axle, this includes the ring & pinion set and master install kits. If you can do it yourself you can save a lot of $$ on labor. Around here its around $350-500 install per axle depending on the shop. Some of the other guys here might have a set of used 4.30s if they went to a lower gear, not sure how many guys have done this though (I don't think many).
To get the parts try:
www.offroadunlimited.com call# on site
www.differentials.com
www.drivetraindirect.com
www.drivetrainwarehouse.com
www.reiderracing.com
www.precisiongear.com
www.ringpinion.com
Hope this helps.
I know that ORU and WCD(www.differentials.com) are in CA not sure how close to you and not sure about the other sites I listed.
