New Member
Old Feb 18, 2023 | 07:17 PM
elbow grease's Avatar
elbow grease
New Member
Glad I found this forum - I am currently working on a 1978 f150 and look forward to riding the river with like-minded people !
I am hoping someone here can help me with this. I have been playing with the carburetor on my bone stock 1978 f150 Custom with a 351m engine. It is a motorcraft 2150 tag #D7TE-AYA and I was wondering how to find out if the booster is original to the carb. On the bottom of the booster is stamped a large L and then a smaller M2 next to it. I ask because I found an exact copy of this carb (another d7teaya) on ebay so bought it for spare parts, and lo and behold it has a different booster in it, this one has a large A and next to it a smaller 3Y. I can tell looking this booster has smaller air bleed holes on top than the other. Am curious which one is supposed to go with this carb - obviously one of them was swapped. It might make tuning a little easier. Any help would be appreciated !
Last edited by elbow grease; Feb 18, 2023 at 08:24 PM. Reason: decided to add more info.
Old Feb 19, 2023 | 08:49 AM
speedfreak78's Avatar
speedfreak78
IDK how to tell what's original, but If you don't know the full history, I'd assume at least one of had been rebuilt at some point. There aren't too many 40+ year old, all original carbs that are still running well.
Just cause the boosters look different and have different markings doesn't mean it isn't designed to work. If one is from a rebuild kit, It could even be an "improved" design to overcome flaws in the original design. Smaller air bleeds could mean a slightly bigger squirt of fuel, which really isn't a bad thing. It could make the transition from idle/low throttle to mid/ high throttle smoother.
Old Feb 19, 2023 | 01:00 PM
elbow grease
Thanks for the reply, you make some good points. As this is specific to the Motorcraft 2150, I think I will try the carbureted sub-forum and see if I get more action.
Wildpat01
18
Jan 17, 2016 06:49 PM
var
Alabama Chapter
68
May 6, 2012 09:53 PM
Fomoko1
Mar 17, 2006 08:02 AM
woodchuck
2004 - 2008 F150
Jan 21, 2005 10:56 PM
