How to remove the knobs on the heater/ac control panel
Old Feb 17, 2023 | 01:04 PM
vettman's Avatar
vettman
How to remove the ***** on the heater/ac control panel
I've done this before but can't remember how I did it. Can someone please help.
Thanks
Old Feb 17, 2023 | 01:15 PM
jflem's Avatar
jflem
Best I recall there is a tab on the back end that you push in and then slide it off the stem.
Old Feb 17, 2023 | 01:46 PM
John89's Avatar
John89
Yes, a tab on the back (probably on the top) use a hook pick and gently pull it towards you and it should slide off. Similar to the washer ****.
Old Feb 17, 2023 | 08:27 PM
vettman's Avatar
vettman
You are correct--I used a small narrow bladed screw driver to dislodge that little tab, and they pulled right off.
Thanks for responding
vettman
Apr 1, 2015 01:07 PM
MattP51
1978 - 1996 Big Bronco
Jul 5, 2011 11:28 PM
F150_Georgia
2004 - 2008 F150
May 2, 2011 06:57 PM
Colo79Ford
Sep 8, 2004 02:09 PM
