Ride Height help...
Old Feb 7, 2023 | 10:27 AM
Jk22's Avatar
Jk22
Ride Height help...
I want my 22 fF250 KR 6.7 to sit as heigh as a 2019 F250. Can I buy a 2019 ford block for the back? If so, whats the part #? Also what did they do to make the front lower on the 20 models?
Thanks
Old Feb 7, 2023 | 10:39 AM
Sonny Crockett's Avatar
Sonny Crockett
You can add a leaf or a block to the rear. The front will be even lower. Lift it or get a level kit. I think they lowered them in 2019.
Old Feb 7, 2023 | 10:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
2020 is when they started lowering the trucks.
Old Feb 7, 2023 | 10:56 AM
DeputyDiesel's Avatar
DeputyDiesel
If you go to the readylift website and read the question sections on on some their leveling kits this question gets addressed by the manufacturer.
Old Feb 7, 2023 | 10:59 AM
Compression-Ignition's Avatar
Thanks
Why do want the back higher? As to the front I would imagine it’s a shorter coil spring, but I never paid attention to how they made the change.
Are you wanting to fit a taller tire or what? Is this for looks? I think everyone who has replied so far just doesn’t understand what you’re trying to achieve.
Old Feb 7, 2023 | 11:17 AM
Jk22's Avatar
Jk22
I am trying to achieve my 22 KR to mimic the same height as a 19 250. The shorter coil in the front as memtioned above makes sense as to why the 22s are lower in the front. I knew they were using a smaller block in the back for the 22s.
Old Feb 7, 2023 | 11:38 AM
4wd6.7L's Avatar
4wd6.7L
The front difference is minimal, around 1/2" lower, the rear is 1". You could source some 17-19 coils, go up in spring rate (assuming yours are base rate), or just toss a 1" spacer in, and swap the rear blocks out. The block part # has been posted in some other threads but I don't know it at the moment.
Old Feb 7, 2023 | 12:12 PM
Jk22's Avatar
Jk22
Thank You...
Old Feb 7, 2023 | 12:23 PM
4wd6.7L's Avatar
4wd6.7L
Thank You...
Try this out for the rear blocks, HC3Z-5598-A and HC3Z-5598-B.
Old Feb 7, 2023 | 12:30 PM
CheeseheadFord's Avatar
CheeseheadFord
Is it that much of a difference where you or anyone else notices the height difference unless you're staring at a 19 beside a 20+? Are you doing it for looks only or functionality for something?
Old Feb 7, 2023 | 12:53 PM
Jk22's Avatar
Jk22
I'm doing it for looks. I can tell a difference. I like the way my 19 SD and my 21 Tremor sat vs my 22.
Old Feb 7, 2023 | 01:39 PM
I would put a post up in your regional chapter and see if anyone who is lifted still has their stock suspension and is willing to part with it. And also call a few local 4wd shops. You should be able to procure those parts free or inexpensive with a little searching and patience. I’d a gave ya mine…
Old Feb 7, 2023 | 02:21 PM
tsmithco's Avatar
tsmithco
I've got some stock rear blocks from my 2018 F250 CCLB. Are you near SW Ohio?
Old Feb 7, 2023 | 03:35 PM
CheeseheadFord
Tire size is going to add to it as well. Tremor has 35s on it.
Old Feb 7, 2023 | 05:26 PM
Rwhjr's Avatar
Rwhjr
https://www.readylift.com/ford-super...t-46-2723.html
they sell the option of a 4” block with it as well.
if you did this 2.5” kit with 4” block it would sit real nice and a little higher than a stock 17-19 truck
i agree with the OP that I like the 20+ trucks with moderate lifts
2-4” with the right tires makes them look so menacing and doesn’t kill it’s usefulness as a truck so it’s a win-win in my book
