Power Steering pump Removal
Old Feb 3, 2023 | 02:15 PM
PrescottGirl's Avatar
PrescottGirl
Trailering
98 Exp 5.4 4x4. Stuck in a parking lot. Have removed the power steering bolts. Cannot remove pulley- it is seized to the pump. Almost destroyed the rental tool. Problem is the pump seems to be frozen to the block.
Last edited by PrescottGirl; Feb 25, 2023 at 10:15 PM. Reason: Remove personal info
Old Feb 3, 2023 | 02:38 PM
RLXXI's Avatar
RLXXI
Originally Posted by PrescottGirl
98 Exp 5.4 4x4. Stuck in a parking lot. Have removed the power steering bolts. Cannot remove pulley- it is seized to the pump. Almost destroyed the rental tool. Problem is the pump seems to be frozen to the block. Please help. I can't afford a mechanic.
The pulley is pressed on the pump shaft, you need a power steering pulley remover/installer tool.
https://www.autozone.com/loan-a-tool...E&gclsrc=aw.ds
Most auto parts stores will loan you the tool.
Old Feb 4, 2023 | 08:45 AM
alloro's Avatar
alloro
Since she said, "Almost destroyed the rental tool" I'm sure she has already tried a PS pulley puller and it didn't work.
My suggestion is to buy a pulley and install it on the new pump.
Old Feb 4, 2023 | 10:41 AM
RLXXI's Avatar
RLXXI
I'm not going to assume anything. If the tool she used isn't working, it's either defective, isn't the right tool or she's not using it correctly. I've done that job thousands of times and that's the tool it's done with linked above. You're not going to just put a new pulley on the new pump without it.
COsby
Modular V10 (6.8l)
Sep 4, 2020 10:20 AM
hwknsdrag
May 16, 2011 08:41 AM
RyAnIs1
May 17, 2009 05:39 PM
tntitan00
Jan 12, 2009 04:32 AM
