Possible your left rear tire is low on air also. I find that this sometimes causes a high pitched rolling frequency that can cause interference with the electrical system.
If that's not it, you could also check your passenger door for scratches.
Check your rear-view mirror. Sometimes if it isnt adjusted right, the vibrations could be transfered through the front window into the window pillars through the dash into the wiring harnesses right into the trucks electrical systems. All kinds of crazy stuff happens then. I've heard it even throws off the voltage regulator.
One time, I kept fouling plugs out left and right, and my truck was running like crap. Upon inspection of the vehicle, I notices a small scratch in the paint on my tailgate. I fixed it with a little touch-up paint and my truck ran great after that, never fouling a plug again. Hmf, who would have figured huh?
Well, one time my truck was running on 2 wheels instead of all 4 wheels. I couldn't figure out why. All my confusion was put to an end when I found some mice under my truck. DUH! My truck was scared of the mice, so it got up and started running around trying to escape them. I set up some traps and took care of the wheel problem. But now it's dancing... yet another mystery.
Most likely it's dancing because of that Ballroom Opera style music you listen to. Try something different. Perhaps you should ask Garrett to lend you some CD's. Then again, that might be a bad idea, because your truck (while listening to that rap style musice) may have a desire to pull its boxer shorts up to its chest, where jeans 3 sizes too big, and pull them down around his knees and start leaving the tags on all its new clothes. You might just be stuck with the dancing
Ah, I love all music man. Depends on my mood. If i'm in a good mood and ready to have fun I can listen to anything and jam to it. If I'm in a bad mood or am tired that day, then country western is all I can listen to, if anything.
I say we stop at the parts store and pick up a voltage regulator, attach it to the ground wire for the alarm system, and play polka music. IF THAT DON'T FIX IT NUTHIN WILL!!!!
