EBP Parts
Old Nov 14, 2003 | 07:12 PM
Iggy_AK's Avatar
Iggy_AK
EBP Parts
Does anyone know where you can buy OEM parts on line for Power Stroke's. I live in Alaska and I'm tired of getting bent over the barrel when I need to buy parts. I can usually find most of what I need on-line but I am having trouble finding someone that has EBP Tubes & Sensors. I have a 97 F-350 that is doing the air sucking thing until it warms up, reading the forums here has lead me to believe that this is the problem, plus I just talked to a Ford Warranty Mechanic and explained the symptoms and he said that the EBP Tube clogs up all the way to the sensor because it dead ends at the sensor. The computer is not seeing the exhaust pressure at the sensor so it's compensating for it until you step on the accelerator.
Old Nov 15, 2003 | 12:48 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You can clean the tube and reuse it if it's not completely full. Lots of carb cleaner and compressed air will do the trick. Or, you could just eliminate the sensor.
Old Nov 15, 2003 | 07:49 PM
Iggy_AK's Avatar
Iggy_AK
Thanks for the info
Thanks for the info, I will take it apart and see if it can be cleaned.
