Sponsored by: Real Truck
Instrument cluster/charging
Old Jan 31, 2023 | 10:20 PM
Robmacp's Avatar
Robmacp
3rd Gear
I have a 2006 f250with5.4
the dash gauge’s aren’t working with key on or running
the vehicle does not charge
Old Jan 31, 2023 | 11:28 PM
donjamer's Avatar
donjamer
Moved to appropriate forum
Old Feb 1, 2023 | 07:05 AM
Robmacp's Avatar
Robmacp
3rd Gear
How do you find appropriate forum
Old Feb 2, 2023 | 08:40 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You have an F-250, so a Super Duty. On the main forums page, scroll down to the "Super Duty/Heavy Duty" section. You have a 2006, so open the "1999 to 2016 Super Duty" forum.
Either way, @donjamer already moved the thread there so you're good, and more of the right folks will see it and help out.
Welcome aboard!
Old Feb 3, 2023 | 12:30 PM
projectSHO89's Avatar
projectSHO89
The cluster MUST operate in order for the charging system to work.
There are three fuses that run the cluster - F45, F33, & F02 in the underdash fuse box. Check them first.
Old Feb 19, 2023 | 10:24 AM
Robmacp's Avatar
Robmacp
3rd Gear
I checked them they are good
Old Feb 19, 2023 | 11:49 AM
p38fln's Avatar
p38fln
You can use a test light to jump from the excite circuit on the alternator to the battery to get it to start charging. You must use a test light don't just use a jumper. You still won't be able to drive the truck because the PCM reads the fuel level off the IPC and will put the truck in limp mode because it thinks you're out of fuel. You can try wiggling the connectors on top of the IPC to get it to turn back on but you probably need a new or rebuilt IPC
Last edited by p38fln; Feb 19, 2023 at 04:19 PM. Reason: Changed "Get" to "Try" oopsie
bluedragin73
1997 - 2003 F150
Apr 26, 2021 04:05 PM
johndoejoe
New Member Introductions
Aug 8, 2018 10:42 PM
ibew
Jan 25, 2016 11:56 AM
f100beatertruck
Nov 1, 2003 07:53 AM
