Hour meter power source
Old Jan 30, 2023 | 05:52 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I want to put an hour meter in the truck for the new engine. I don’t want to power the meter when the key is in RUN but the engine is actually off. Would tapping into the oil pressure sending unit or the tach signal wire be a good source without causing those circuits to act weird? Any other thoughts for a power source? As a side note: I converted the oil gauge from an “idiot light” to a real gauge so it has a real sending unit and not a switch.
Old Jan 30, 2023 | 06:04 PM
hobohilton's Avatar
hobohilton
Gas or diesel ?
Old Jan 31, 2023 | 03:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
on the big trucks the hour meter is tied to the tach. key on engine off no hour meter reading. engine on hour meter runs.
Old Jan 31, 2023 | 03:51 AM
My4Fordtrucks
Originally Posted by hobohilton
Gas or diesel ?
Gas - 351W
Thanks. That’s the circuit I’ll use.
Old Jan 31, 2023 | 03:55 AM
tjc transport
i ain't rite
just tag the meter feed to the power into the tach circuit. that should not disturb the signal going to the tach.
Old Nov 12, 2025 | 12:25 PM
My4Fordtrucks
I eventually got around to this over the summer for the new engine. I used an extension with two ports so I can use the oil pressure sending unit for the gauge and switch to run the engine hour meter.
Old Nov 16, 2025 | 05:15 PM
Prototypemech's Avatar
Prototypemech
I would not tie anything into the ignition system of these trucks. The PIP and ICMs are finicky and even unmodified systems have problems; don't **** it off by adding another load to it.
Real industrial equipment and airplanes use an oil pressure switch to run the hobbs meter. I suggest you follow their example.
If you wanna be slick, you can add a relay to your current oil-pressure switch. When the oil pressure is low, it'll turn on the "low oil pressure light". When the oil pressure is high, it'll turn on the hobbs meter.
Old Nov 16, 2025 | 05:38 PM
cougrrcj's Avatar
cougrrcj
Just for a point - Aircraft have 'Tach time' and 'Hobbs time' . This can translate to cars/trucks where they count 'Idle Time' like newer police cars so sitting at idle at a speed trap/or while writing a ticket counts counts as one measure, and high-speed pursuit counts as another for wear/tear on the engine. Using an oil pressure switch would count as Hobbs Time.The difference between Hobbs and Tach time is the following:
  • Hobbs Time:
    • The time from when the engine starts to when the engine stops.
  • Tach Time:
    • At cruise RPM, tach time counts like a standard clock.
    • At an RPM less than cruise, tach time counts slower than a standard clock.
    • At an RPM more than cruise, tach time counts faster than a standard clock.
Old Nov 17, 2025 | 04:24 AM
My4Fordtrucks
Which is what I did. The current oil pressure switch that I added for the hour meter? I suppose wiring it into the red engine light might catch my eye more than a needle in the wrong place on a gauge but I’m good with what I have.
Hobbs Time:
That was the goal. I wanted to track engine run time.
tgun
Mar 17, 2019 03:06 PM
johnmel59
22
Nov 27, 2014 08:12 AM
gysgtbigdaddy
Electrical Systems/Wiring
Jul 11, 2014 08:42 AM
Leathw
Jul 14, 2003 04:04 PM
Dog_Brains
Jun 28, 2001 11:37 PM
