Oil temp -76F ?
Old Jan 28, 2023 | 06:50 PM
Garbageman 134's Avatar
Garbageman 134
Oil temp -76F ?
While cycling through the menus on the dash I came upon the temperature screen and I'm curious why it shows the oil temperature with a negative. Is monitoring oil temp an option on a higher trim level?
Old Jan 28, 2023 | 07:00 PM
Pbergmann's Avatar
Pbergmann
Maybe it's colder outside than you think?
Are you in Alaska?
Old Jan 28, 2023 | 07:13 PM
Garbageman 134
Are you in Alaska?
This is being displayed after the truck is warmed up
Old Jan 28, 2023 | 07:17 PM
wylecoyote's Avatar
wylecoyote
My 2019 LARIAT monitors oil temp.
Old Jan 28, 2023 | 07:23 PM
4wd6.7L's Avatar
4wd6.7L
Old Jan 28, 2023 | 07:42 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Bad sensor???
Old Jan 28, 2023 | 11:17 PM
HRTKD's Avatar
HRTKD
Hey, at least it isn't an "ID 10 T" error. As suggested above, sounds like a sensor or wiring fault. On my LiFePO4 battery, the BMS will display a temperature of something like -40°F when the sensor isn't plugged in. So that's why I mention the wiring.
I did have a DEF injector error last year and it was resolved by the dealership with a programming update.
Old Jan 28, 2023 | 11:29 PM
4wd6.7L's Avatar
4wd6.7L
The thread I posted above tells me that gas engine Super Duty's, like the OP has, may not have an oil temp sensor. It sounds like most gas Duty's come with that oil temp view disabled.
Old Jan 28, 2023 | 11:37 PM
HRTKD's Avatar
HRTKD
Ah, good point. I have my Power Stroke blinders on.
Old Jan 29, 2023 | 08:19 AM
chadstickpoindexter's Avatar
chadstickpoindexter
The thread in post number 5 is what I thought of when I saw this title. No oil temp sensor in the 7.3's.
But, I see your -76 and raise! I once saw -800+ on my transmission temp on my iDash! By the time I snapped a picture it was down to -790... LOL
Farmboypowerstroke
Apr 2, 2010 08:49 AM
BrianA
Oil & Lubrication
Mar 25, 2003 09:51 AM
dave thomas
Oct 1, 2001 11:07 AM
