2017 front end torque specs
Old Jan 27, 2023 | 08:42 PM
F350_256's Avatar
F350_256
3rd Gear
2017 Ford F-350 4WD. Just replaced the drag link and passenger side end along with the stock steering damper. I found a drawing showing in the 1999 to 2016 Super Duty forum that showed all the specs. Looks like all the same components. Are these specs valid for 2017?
If not where can i find a similar drawing with torque specs?
Old Jan 27, 2023 | 09:00 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Steering dampener to drag link - 66ft-lbs
Steering dampener to frame - 59ft-lbs
Drag link to pitman arm - 129ft-lbs
Tie rod end - 85ft-lbs
Tie rod adjuster sleeve nuts - 41ft-lbs
Old Jan 27, 2023 | 09:10 PM
F350_256's Avatar
F350_256
3rd Gear
Same specs I saw on the drawing. Thanks!
Old Oct 9, 2025 | 05:29 PM
Ezdumpbl's Avatar
Ezdumpbl
4th Gear
2017 F-250 front end torque
do you know the track bar torque specs?
Old Oct 10, 2025 | 04:44 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
184ft-lbs at the ball joint.
406ft-lbs at the frame mount.
Torque while the weight of the vehicle is on the suspension/wheels.
joe blow
Aug 25, 2017 07:46 AM
rtazz17
May 6, 2011 11:20 AM
EburgHDFord
Jul 22, 2005 12:49 PM
karenj
Feb 12, 2005 10:38 PM
BB
Jul 19, 2002 06:07 AM
