Support bracket for starter motor.
Old Jan 26, 2023 | 02:03 PM
Rubiranch's Avatar
Rubiranch
I am looking for the starter motor support bracket that was installed by the factory on some FE engines.
I used to hate them in the old days and I think a lot of folks just tossed them into the garbage rather than reinstalling them.
The bracket bolted onto the rear of the starter motor. The two bolts that hold the stater together had studs on the end of them.
The bracket went there and then bolts held the bracket onto the starter.
Then there were two bolt holes where the bracket was bolted to the block.
I would really like to find one of those brackets.
Maybe Rich can find a picture of one and share it for us.
Kenny
Old Jan 27, 2023 | 10:46 AM
5851a's Avatar
5851a
The last I remember them used on was flatheads and chevys. Was it on a FT engine?
Old Jan 27, 2023 | 12:11 PM
Rubiranch's Avatar
Rubiranch
Its been forever since I saw one but i do remember what a pain ot was to change a starter with one on ot.
And I do remember them being on 360 390 428 engines. Just can't remember the years and models.
My truck has broken two starter drives and I think its because the starter motor has a small amount of movement.
Old Jan 27, 2023 | 02:07 PM
5851a's Avatar
5851a
Only pita place it could attach would be the tapped hole about even with #4 main bearing. If anyone has one it would be Rich.
Old Jan 27, 2023 | 03:07 PM
Rubiranch's Avatar
Rubiranch
And I sure hope he does.
Old Jan 27, 2023 | 05:05 PM
tbear853's Avatar
tbear853
Or maybe fab one?
I vaguely remember seeing one on a friend's '61 Starliner with 406, helping to change out a starter.
Old Jan 27, 2023 | 08:25 PM
somethingclever's Avatar
somethingclever
How exactly are the starters failing?
Old Jan 27, 2023 | 10:39 PM
440 sixpack's Avatar
440 sixpack
I have FE's that were bought new by my dad and they never had one, I've never seen one. I wouldn't bother with one.
Old Jan 28, 2023 | 02:07 PM
Rubiranch's Avatar
Rubiranch
Its busted two stater drives. I'm thinking its due to the started motor moving.
Old Jan 28, 2023 | 05:05 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I do not know of this part you are talking about and or have never seen one either. But I have a 76 F100 parts truck with an all stock 360 that still has the starter, do I need to pull the starter and see if it has a stand alone detachable part?
Old Jan 28, 2023 | 07:29 PM
440 sixpack
You have something wrong then, probably a meshing issue. possibly caused by an incorrect bellhousing to flywheel match up, though I can't imagine what that would amount to.
In 45 years of messing with FE's I've never broken a starter .
Old Jan 28, 2023 | 07:54 PM
john jamieson's Avatar
john jamieson
Is your starter the newer style or one with the big bendex on it that is centrifically operated. I have a 390 in my '64 and have some fitment issues that cause mine to eat the bendix units at times. My issue is a mismatch of parts that a PO used to swap in the 390.
Old Jan 28, 2023 | 10:33 PM
somethingclever
I also have never seen this bracket in car or truck applications.
closest thing is a stamped steel brace that ran behind the starter from the block to the trans bellhousing in a 1968 460…..but it didn’t tie into the starter anywhere.
Old Jan 29, 2023 | 05:23 AM
Rubiranch's Avatar
Rubiranch
Its weird for sure. As far as I can tell everything should match up.
410s are 390 blocks, factory bellhousing for a 360 and a new 428 flywheel.
Theoretically it should work.
The starter drive actually breaks into pieces.
Old Jan 29, 2023 | 05:27 AM
Rubiranch's Avatar
Rubiranch
Here's the first one that broke.
I don't have the one that's broken right now off the truck yet. Hopefully Monday.
