Dashboard Lamp
Old Jan 25, 2023 | 03:46 AM
Niggi's Avatar
Niggi
Dashboard Lamp
Hello, I have another question about my Ford f250 `71. And what is that for a lamp in the dashboard, I have this too, but unfortunately it doesn't work. Can someone tell me what it is for?
Thank you for your answers.
Manuel
Old Jan 25, 2023 | 06:21 AM
Niggi's Avatar
Niggi
After some research, I believe that this is the control light for the brake system, which should not light up in normal operation.
If i'm wrong please correct me.
Old Jan 25, 2023 | 08:11 AM
Centennial F100's Avatar
Centennial F100
Here's a good thread on the topic
centralizing brake pressure differential valve - Page 2 - Ford Truck Enthusiasts Forums (ford-trucks.com)
I noticed the link I attached started at page 2, you should go to page 1 to see all.
Last edited by Centennial F100; Jan 25, 2023 at 08:15 AM. Reason: Link of thread doesn't start on page 1
Old Jan 26, 2023 | 12:57 AM
Niggi's Avatar
Niggi
Many thanks for your response.
Old Jan 29, 2023 | 11:16 PM
JEFFFAFA's Avatar
JEFFFAFA
That's so you can see "Paradise by the dashboard lights".
All kidding aside, that light should come on when you first turn the ignition switch on. This is to prove the bulb is good. Then should only be on when you have a brake system off balance.
Old Jan 30, 2023 | 11:49 PM
Niggi's Avatar
Niggi
Old Jul 10, 2023 | 09:55 AM
Niggi's Avatar
Niggi
Hello I have a question about the brake pressure warning lamp. Is it the 1445 or 1895 and how many watts does the bulb need.
Many thanks for your messages.
Manuel
Old Jul 10, 2023 | 01:27 PM
Green72F250's Avatar
Green72F250
According to this chart it is a 1445
Ford Truck Part Numbers (Miniature Bulb Application Chart) - FORDification.com
Old Jul 13, 2023 | 01:12 AM
Niggi's Avatar
Niggi
Many thanks.
Fishyboy123
15
Dec 11, 2024 05:04 PM
WRCR
68
Jun 6, 2023 08:59 AM
GreenMtnMan
Dec 25, 2022 01:07 PM
