351m oil pressure problem
Old Nov 14, 2003 | 03:36 PM
bruce351's Avatar
bruce351
Hello, I've recently replaced the cam,intake,carb in my 351m
and before I did this, my oil pressure seemed to be fine. Now when I start it, the engine runs at 65lbs. When it warms up it drops to just above 5lbs. What is my problem, I drained the
oil, hopingto get some junk out.It didn't help.
Old Nov 14, 2003 | 03:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to engine forum.
Old Nov 14, 2003 | 04:18 PM
79_250RangerLariat's Avatar
79_250RangerLariat
How many miles are in the engine? I take it your using a mechanical gauge, sure it's working correctly? You'll probably find the main/rod bearings are worn...
Old Nov 15, 2003 | 05:51 PM
thisoldford's Avatar
thisoldford
main bearings are more than likely the cause.
Old Nov 18, 2003 | 05:29 AM
bruce351's Avatar
bruce351
MAIN BEARINGS
tHANKS FOR THE HELP, i ASSUMED THE MAIN BEARINGS WERE MY
PROBLEM. i WAS HOPING SOMEONE HERE MIGHT HAVE ANOTHER
SUGESTION.
THANKS
