Another sending unit question
Old Jan 23, 2023 | 08:15 PM
dairydude's Avatar
dairydude
I did an underbed gas tank from a 69 mustang. When I hooked up sending unit to the OE 56 f250 gauge, with the float in the empty position, the gauge reads 3/4, full is all the way to the right past full. I tested the sending unit, instead of reading 10-70 ohms, it reads18.5-85 ohms. I even ordered the better one with a brass float. Do I spend another $35 or live with it? Aren't they more accurate than that?
I also bent the stop for the float arm, and it gave me more range but when but when it goes.past the solder bump contact on the inside, it clicks. Could that cause a spark and explosion? Should I try a different one? Had it a year, don't think I can return it.
Old Jan 24, 2023 | 09:52 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Empty Full Vehicle Application
0 ohms 30 ohms Most pre-'65 GM
0 ohms 90 ohms Most GM 65-present
16 ohms 158 ohms Most '87-present Fords
73 ohms 8-12 ohms Most Fords before '87 and most Chrysler
240 ohms 33 ohms Use with 3262 sender
10 ohms 70 ohms Ford Bi-Metallic Gauges (pre-1987 F-Series Trucks)
15 ohms 160 ohms Ford Magnetic Gauges (1987 and later F-series Trucks)
You'll probably need something like this. https://www.ebay.com/itm/23454223660...xoCtQMQAvD_BwE
Old Jan 24, 2023 | 11:13 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
I believe 56 was a 1 year only type gas gauge that was a 12V king-seeley type (not ohm/resistance based).
6V king-seeley was used through 55 and again in 57 onwards with voltage dropper circuitry.
Regardless, you won't have a good time mismatching king-seeley and ohm/resistance equipment.
Old Jan 24, 2023 | 07:45 PM
hooler1's Avatar
hooler1
bmoran is exactly right. The gauge has to match the sender. The stock 56 Fuel gauge sender uses heating coils, bi-metalic contacts, on and off current to get a reading to the dash gauge. You would be much better off going to a stock looking aftermarket fuel gauge and sender set up from Mid Fifty if you could. Check it out here:
https://www.midfifty.com/item.php?IN...-sender-kit-56
Also while visting that page, scroll down, click and look at the handy pdf docs they have on the aftermarket gauges, and trouble shooting.
Old Jan 24, 2023 | 08:01 PM
bmoran4's Avatar
bmoran4
@hooler1 , I doubt that sender will directly fit the 69 mustang gas tank directly. It seems that the sending unit in that kit is an adoption of the 3262 which matches the 240-33 ohm range specified by their aftermarket gauge and is discussed here: https://www.ford-trucks.com/forums/1...l#post10137118
Old Jan 25, 2023 | 05:26 PM
hooler1's Avatar
hooler1
Yes Gotcha! I am sure you are correct about that. I just wanted to put it out to him, for him to see if it was something that he could think about anyways.
Old Jan 26, 2023 | 06:01 PM
dairydude's Avatar
dairydude
So the ohm range converter won't work with the oem guage and 69 sender? Has anyone cut a hole in the top of the tank and install the 56 oem sender in a mustang tank? You can tell I'm a tight ***!
Old Jan 26, 2023 | 06:08 PM
bmoran4's Avatar
bmoran4
A resistance/ohm range converter will not work in your situation. The linked thread I referenced earlier shows exactly how a member cut a hole in a 69 mustang tank, but for the aftermarket 3262 sender for use with an aftermarket but OEM looking gauge. I presume doing the same for the stock sender for use with a stock gauge would be similar.
Old Jan 26, 2023 | 07:12 PM
bjmayberry2
I have a 56 with a G10 tank and sender (Empty 0 to 90 Ohms Full) with a Tanks Inc Meter Match. This seems to work well.
https://www.tanksinc.com/pdf/MeterMatchInstructionManualTanksInc.pdf
https://www.technoversions.com/Faq.html
I had it out today changing out my temperature gauge. It's a MidFifty set sender and gauge. I called MiFifty and asked about a fuel gauge that would read a G10 sender and they only have gauges for "their" sending units and stock.
Old Jan 26, 2023 | 07:29 PM
bmoran4's Avatar
bmoran4
The MeterMatch documentation states it is for resistance/ohm based systems, not king-seeley pulsed.
Old Jan 26, 2023 | 07:54 PM
bjmayberry2
I'm not arguing. I just said it's working for me.
Old Jan 26, 2023 | 10:26 PM
hooler1's Avatar
hooler1
The MeterMatch documentation states it is for resistance/ohm based systems, not king-sealy pulsed.
Tight? Naw! I am the same only I prefer to think that I am economically creative.😀
Old Jan 27, 2023 | 10:03 AM
bjmayberry2
I email Meter Match last night. Here's their answer.
"Hi BJ -
Ah, you have the combination that could work. If this sketch that I found on-line is correct, I think it's likely that what you have could work.
Regards,
Brian"
Old Jan 27, 2023 | 10:14 AM
bmoran4's Avatar
bmoran4
The image did not come through. I'm very curious to see how they think the OEM 12V King-Seeley gauge would work with a resistance signal instead of the pulse signal accurately... I mean in theory, they are incompatible protocol signals, but it is technically possible for the "averaging out of the pulses" to be roughly equivalent to a certain resistance and give the appearance of "working" at certain frequencies. I'm going to have to crack out the oscilloscope and investigate... hopefully the image can be posted correctly to steer my experimenting. And, if the MeterMatch did actually engineer the some pulse averaging magic, that should be touted and marketed as a feature.
Old Jan 27, 2023 | 10:19 AM
bjmayberry2
The image did not come through. I'm very curious to see how the OEM 12V King-Sealy gauge would work with a resistance signal instead of the pulse signal...
Not sure what happened but I think I fixed it.
