Rear Cab mount plugs
Old Jan 23, 2023 | 01:16 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I realize in many places it states these holes are 1 1/2" but since I replaced my entire cab back a 1 1/2" plug falls right thru. Since my bed is mounted and the inside of my cab has been covered with sound deadening I can't get an accurate measurement on the hole size. Has anyone run across this and if so what size plugs did you end up using?
Old Jan 23, 2023 | 01:57 PM
abe's Avatar
abe
I had to use black adhesive to keep mine in place after my 54 was repaired and painted.
How many of your plugs are now forever lost between the cab corner and the inside cab sound deadening? LOL
Old Jan 23, 2023 | 02:00 PM
Last chance 53's Avatar
Last chance 53
I have the new back panel like yours I will go out to the shop and measure.
Old Jan 23, 2023 | 02:08 PM
Last chance 53
Just measured, 1.440''
Old Jan 23, 2023 | 04:21 PM
Brian1950F4's Avatar
Brian1950F4
You might check to see if a plug used to block off an unused electrical knock out would work. Very similiar in style and a variety of sizes available.
Old Jan 23, 2023 | 04:41 PM
Greg Rogers's Avatar
Greg Rogers
I bought plugs for mine-( I think Mid Fifty) fit just fine.
Old Jan 23, 2023 | 04:47 PM
bjmayberry2
Greg, that's what I bought that don't fit.
Brian, I'd like to get rubber plugs so they can be removed to take the cab off. The problem is I don't know what size these holes are. Very possible the holes are even metric. I'd bet the cab back was made in China.
Old Jan 23, 2023 | 05:34 PM
Last chance 53
I don't why your back panel is different than mine, hard to believe that more than one die is used to stamp these, any chance the body shop opened them up?
Old Jan 23, 2023 | 05:38 PM
bjmayberry2
Originally Posted by Last chance 53
....any chance the body shop opened them up?
Only they know that. ANYTHING is possible. I've not had good luck with bodyshops.
Old Jan 23, 2023 | 05:41 PM
Last chance 53
Here is what mine looks like
Old Jan 23, 2023 | 07:20 PM
bjmayberry2
I don't think mine has these.
Old Jan 23, 2023 | 07:32 PM
abe's Avatar
abe
BJ, is your whole back panel a reproduction piece? If so that's why, I'm thinking.
Were they there for strength?
Old Jan 23, 2023 | 07:44 PM
bjmayberry2
My whole panel is one piece but I used my old frame stuff, around the window, etc.
Old Jan 23, 2023 | 07:53 PM
Last chance 53
Those are plug welds that attach it to the rear support, mine is one piece also, I bought it after seeing you were using one!
Old Jan 23, 2023 | 08:24 PM
Brian1950F4
You can get a weather resistant style. They are a 2 piece with a rubber gasket.
