22 F350
Old Jan 21, 2023 | 09:16 AM
tpctec's Avatar
tpctec
22 F350
What is the lower threshold for tire pressure before the TPMS sets code? 22 F350 4x4 SRW Reg Cab STX, Thanks
Old Jan 21, 2023 | 11:01 AM
morehouse7's Avatar
morehouse7
I believe when a sensor detects tire pressure below 25 percent of your recommended pressure, this would be set based on the sticker in your door jamb. You can change those parameters with Forscan.
Old Jan 21, 2023 | 11:19 AM
4wd6.7L's Avatar
4wd6.7L
Part of the mandate requires the tpms light to come at no more than 25% psi difference compared to recommended psi. Manufacturers can set them to trigger at less than 25% though. The one time my light came on it was 20% below recommended pressure.
Old Jan 21, 2023 | 11:41 AM
2021F350's Avatar
2021F350
Mine came on when I lowered them down from 80Psi to 62Psi for the rears, the fronts are lowered from 60Psi to 50Psi, and haven't triggered the low tire pressure warning...
Old Jan 21, 2023 | 11:45 AM
gSwift's Avatar
gSwift
Lower them to 40 or 45psi in FORScan and never worry about it again
Rick_V
Mar 21, 2022 05:38 PM
Linemo
Mar 21, 2004 05:44 PM
