Rebuild info
1995 F150 351w/e4od
e303 cam
1.7 roller rockers
TFS2500-100 valve springs
arp head studs and rod studs
Ended up with this cam before I realized it wouldn't work with speed density. I know I will need new computer/harness. With my upgrades I'm wondering if I will get away with just junkyard parts from a different MAF setup. At what point do I need chips/tunes to make it run? Eventually I do want to fine tune just to make sure I'm running as good as possible but for now I just want to get it running fine. thanks in advance
