Rear End
Old Jan 26, 2023 | 10:35 AM
Scndsin's Avatar
Scndsin
Try & get the info off the tag, probably never been changed.
Do you have a tach?
Also 8.8 truck rears are plentiful, relatively cheap & easy to change.
Ought to be easy to trip over in GA.
Old Jan 26, 2023 | 10:38 AM
runninvtec's Avatar
runninvtec
Trailering
Okay. I will look. are you talking about the tag that sits under the hood?
Old Jan 26, 2023 | 10:43 AM
GNR22's Avatar
GNR22
The tag he showed will be bolted to the cover on the center section of the rear axle.
Are you positive that the truck is actually using all 3 gears?
Old Jan 26, 2023 | 02:00 PM
Mudsport96's Avatar
Mudsport96
Can't be with a factoryrear gear. Third at 5k is triple digit speeds. Unless the tach is wrong or someone swapped in a 5.xx gear.
Old Jan 26, 2023 | 02:14 PM
GNR22's Avatar
GNR22
Since we don't know the gear ratio, I'm just spit balling here but to explore possibilities knowing the rest of the truck, a C6's gear ratios are 2.46:1, 1.46:1, and 1:1 (or at least that's what I recall off the top of my head).
If you only make it to 2nd gear, with a 4.10 gear, a 29" tire, and 70 MPH is about 5000 RPM.
If you're stuck in 1st gear, with a 3.08 gear, 29" tire, and 60MPH is about 5000 RPM.
Is this truck 4 wheel drive? Is the transfer case stuck in low range? Transfer case reduction ratio on a BW1356 is 2.69:1.
Old Jan 26, 2023 | 02:18 PM
Hit Man X's Avatar
Hit Man X
I was going to mention that also...maybe it is not upshifting into third.
Old Jan 26, 2023 | 03:41 PM
GoinBoarding's Avatar
GoinBoarding
Yea it can't be? I run my E4OD in 3rd fairly often. 4.10 gears, 33" tires, and while yes I have a lockup converter it isn't anywhere near 5k RPM. In 2nd I'll run it out to 65 mph on occasion and that's up over 4k RPM, without lockup & going 70 mph I'd be getting near 5k RPM. I bet that C6 isn't going into 3rd.
351_ranger
Jul 11, 2021 09:44 PM
Adam Woolridge
Feb 11, 2019 06:35 PM
672wd72highboy
27
Jun 14, 2014 12:24 AM
miashley150
Feb 3, 2013 06:50 PM
ALSAIR
1978 - 1996 Big Bronco
May 12, 2004 05:56 AM
