broken manifold repair bracket
Old Jan 12, 2023 | 08:42 PM
fishmanndotcom's Avatar
fishmanndotcom
I recently discovered the exhaust manifold bolt on the drivers side next to the firewall is busted and of course the manifold is leaking. i came across the repair bracket on CPAddict's site (7.3 Driver Manifold Bolt Repair Bracket) and was curious if anyone else has had luck using it. I am thinking it will be best to just pull the manifold off and replace the bolts but if this bracket is solid i might give it a try.
Old Jan 13, 2023 | 07:28 AM
Jrgunn5150's Avatar
Jrgunn5150
I see no reason why it wouldn't work. They sell similar products for LS/Vortec engines that work fine.
Old Jan 13, 2023 | 08:42 AM
knottyrope's Avatar
knottyrope
i installed one last month on mine when doing buppies and i didnt have much of a gap.
lot more quiet now
Old Jan 23, 2023 | 04:44 PM
fishmanndotcom
ok so just to close the issue here i ended up just removing the manifold and removing the broken bolt. removing the inner fender liner and the shock tower helped a TONNNN (highly recommended). i took the manifold to a machine shop to have it re-surfaced and will reinstall as soon as i get it back.
JMG1
Nov 13, 2013 03:33 AM
diesel-fitter-bum01
Dec 15, 2011 12:50 AM
jutahh1
Modular V10 (6.8l)
Jun 18, 2007 09:42 PM
jakegypsum
Dec 5, 2001 11:24 PM
dillon
Sep 25, 2000 02:02 AM
