1967 F-100 Progress Thread
So the story goes, last week a friend called me and she asked me and my brother if we wanted to help the lady that lived in The Goonies House move. Yes, the one from the Movie. So of course we wanted to. I made a joke to my mom saying, “The only reason I’m doing this is because I want a classic car and she may have one.” But that was just a joke. I wanted to see the inside of the house. So I get off work and head to the house and start unloading it. We get a full load and take it to her new home and a surprise was sitting on the neighbors field! A 68 Ranger 250 and a 69 Ranger Dully and a 67 F-100. Now the first two were owned by Mother Nature from sitting for so long but the 67, it didn’t look so bad. My brother went over and knocked on the persons door and asked about the trucks. She said that they were her brothers and he wasn’t selling them but he would probably take 1k for all 3. I called my Grandpa who’s was a mechanic and he took us over the next day too look at the trucks. And the mom of the lady that we spoke to the day before came out and talked with us for a while. She said that they were her husbands trucks and he died a few years ago suddenly from brain cancer. She had been trying to get here son to take them off the property for 10 years and he didn’t so she gave the 67 to us. We didn’t want the other 2 because we didn’t have the space, but she said we could pull whatever parts we wanted off them. We of course took her up on the deal. We got the truck loaded up and brought it to our house and we got to work. We put a new battery in it and twisted the key and it fired up immediately. It was too good to be true. And it was. I changed the Oil and added coolant. We ran it and it wan real good, 50 Psi Oil pressure, but as soon as the thermostat turned on we figured out why it was parked. It was leaking a bunch of coolant out of the block. Great. I’m hoping it’s just as easy as replacing the freeze plugs but I guess I’ll see tomorrow. Also the exhaust manifold has a exhaust leak. And the valve covers leak. Also I popped a brake line when I was loading it on the trailer. So I’m gonna put all new brake lines in it and hope I don’t have to replace the slaves because I don’t wanna pull the drums. Also gonna rebuild the carb, replace the valve cover gaskets, manifold gaskets, and try to get the after market pioneer boom booms working again.
So here are some of our before and after photos. I made some patina shine juice. It’s got a 352 4 in the floor. I’m gonna keep my eye out for a no engine or trans car with a good body to put this engine and trans in. If I don’t find one for a decent price by the Rod Run in Longview Washington. I’ll sell it at the car show for 1500 or something unless somebody has some ideas for how to fix the rust holes in the top of the cab. I may bring it to a local body guy I know. He might be able to do something for a decent price.
Before
After
Before
After
Before
After
Before
After
After
After
It’s rotted like this on both sides. What are my options? Is this truck any good?
Its pretty rusty, but could be fixed, as the old saying goes, "if it will cast a shadow, it can be restored" All it takes is time and money.
As was said, a different cab would be the easiest way to improve your trucks status.
Kind of a bummer that its a 67, as they are kind of a one year only deal. I am not sure if a 68 - 72 cab would swap, or not? You would end up with a frankin- truck, but it would increase the odds of finding a doner cab.
You mentioned swapping the engine / trans into a car.
Ford as you may have already found out did not make swaps of this sort an easy deal. Unlike GM where things are easy to mix and match, with engine / trans from different years, makes, models, our friends at Ford make many different configurations, and many are unique to an engine family.
In case you do not know what mixes and what don't, here are a few examples.
352, 360- 390 - 410- 427 & 428, share a common bell housing bolt pattern, that is sort of a round shape.
1965 and up 289s, 302, 351 W, 351 C, share a common bell housing bolt pattern. Early 260's and 289's, until some time in early 65, used a unique 5 bolt pattern.
351M, 400, 429, and 460 use the same pattern.
Truck bell housings on manual transmission are about 1/2 inch shorter, or longer than a car bell housing, but I cant remember which way it goes. But they dont exchange.
Engine mounts also have some variations, in what will fit and bolt up, and what needs a little help with custom fab mounts.
For reference, on your intended engine to car swap, the last year Ford used the FE engine in a passenger car was 1970.
Any car that had an FE engine option, would accept your 352 engine, with factory mounts. The trans you have would require major mods, to fit in any car.
Best of luck to you and dont give up.
I'm assuming the cab front drip rail is just as bad. Are the roofs any better on the other two Bumpsides? Your body man friend may be able to transplant one of them.
I appreciate you guys a lot! I’ll probably end up with another one soon.
