keyless entry codes?
Old Nov 14, 2003 | 07:11 AM
encorick's Avatar
encorick
just bought an '01 EB Expy. It has the keyless entry.
How/where do I locate the keyless entry code?
Call ford?
Old Nov 14, 2003 | 07:29 AM
Voksboy's Avatar
Voksboy
I'm not sure but your best bet is to call ford or ask the seller.
Old Nov 14, 2003 | 07:39 AM
D2EBMA's Avatar
D2EBMA
Actually, your best bet is to stick your head under the drivers side dash. The code is printed on a paper sticker affixed to an electronic box located under the dashboard. The box is up under the dash near the parking brake assembly.
Old Nov 14, 2003 | 09:12 AM
encorick's Avatar
encorick
Wink
Thanks guys!
I will poke around under there this afternoon!
Old Nov 14, 2003 | 10:49 AM
1999XLT's Avatar
1999XLT
Its the 6 REALLY big numbers under the drivers side dash....
Old Nov 14, 2003 | 01:53 PM
FarmLaw's Avatar
FarmLaw
Correction: it is the 5 really big numbers...black numbers on a white sticker. The owner's manual indicates how you can reprogram the code to whatever you want when you have the original code.
Old Nov 14, 2003 | 02:15 PM
1999XLT's Avatar
1999XLT
Thats what happens when you tipe to fastr. My badf.
Old Nov 15, 2003 | 01:39 AM
PaulC's Avatar
PaulC
You can never erase the original code, but you can add a second code which will also work. Key in the original code, press the [1|2] button, then key in the second code.
BTW, you should have a credit card-sized piece of plastic with the keycode in the owner's manual packet.
Old Nov 15, 2003 | 01:58 AM
encorick's Avatar
encorick
Got them!
No plastic card, but the numbers were right there as described...
You folks are top notch!
Old Nov 28, 2003 | 10:43 AM
TodzY2KExpy's Avatar
TodzY2KExpy
kewl!
Thanks: I found mine too !
Old Nov 28, 2003 | 10:48 AM
emtabmm's Avatar
emtabmm
Adding a code is well and fine but remember this....
If the battery goes dead or you take unhook the battery for any reason the 2nd code is erased, on my cars I have found it easier to remember the original code....
