tires for 2002 exp
Old Nov 14, 2003 | 06:38 AM
rpm5099's Avatar
rpm5099
Question tires for 2002 exp
I just bought a used 2002 XLT Explorer V8 4WD and it has the stock 235/70 R16 tires on it. Id like to replace them (although I cant justify it for another couple months, haha) with the new Bridgestone Revo's. My question is this - do i need to get 235/70 tires on the replacement - or can i get a wider tire such as 245 or 255? Can I expect performance advantages from this - or will it just bind up and/or damage my auto-4wd (which is the only feature of the car I cant stand and Id like to just disable it). Im not a novice, but I have little experience with tires. Thanks for any opinions.
Old Nov 14, 2003 | 07:36 AM
Bob Ayers's Avatar
Bob Ayers
I suggest staying with the stock size tires. Unless you change the
dif. (front & rear) ratios, your performance (and gas mileage) will
drop with larger tires.......
Old Nov 16, 2003 | 07:04 PM
rpm5099's Avatar
rpm5099
I dont plan on changing the wheels either, so my understanding is that I have to keep the exact tire size, becuase wheels are tire size specific. If i were going to buy new wheels, I would make the tires larger anyways. I dont have the $$ to do both, although I wish I did.
