How long have trucks been made? And we still have to put up with wobble?
Which trucks? Seems like a common thing with Ford, GM and Dodge. Maybe the issue is that there is no real fix to the problem. Not without using better components which cost more money and people aren't willing to pay for anything more than lip service from the manufacturer. Before and after purchase, the buyer swears he will pay more for a better truck. During purchase time, he will shop for the lowest price.
have you checked lately how much a mid trim super duty costs these days?
I'm not sure where we are going with this. Isn't it measured by "lately dollars"? I would take your mid trim SD and measure it against a GM and Dodge equivalent in "lately dollars" and see what to do. Sure, other factors like resale are a factor but isn't everything measured in "lately" and not what you paid for it as a kid?
There is a fix for it, more Caster, but the downside is that it stiffens steering, puts more strain on the steering gear box, and something the manufacturers would like to not have as it could lead to potential gear boxes failing long before they are due. They compromise to get the girlie smooth steering effort for the soccer moms to be able to park in the malls instead. Parts wear regardless of how good they are made, that is a LOT of weight on the front end that they have to deal with, especially on how bad the condition of roads are today. With more Caster, it is less likely to cause a DW when bushings and joints start to wear.
I see most of the trucks around here that are north of 1/2 ton are driven by men. And if their areas of visit are mostly parking lots, it would be stupid to design it for some hick in the sticks if that isn't their audience. Yes, regardless of how good they are, parts wear out. They wear out sooner if they are not good. Maybe that is the first place to start before the caster change. I didn't change caster. Just upgraded the parts. That puts a lot more money for production costs which the consumer doesn't want to pay regardless of what they say.
You brought up a valid point, "a lot of weight"
im wondering if diesel trucks have the wobble more often than the gassers?
fords always command higher prices than GM and Ram trucks of a similar classification. The profit margin on these trucks is adequate enough for Farley to keep around to subsidize the EV push. If you don’t see the value in trading some costs in R&D and production of gizmos and gadgets for better wear components, I accept the fact that nothing I say will convince those who care about electronics more than durability.
Assuming the front end suspension and driveline components are the same, the diesel trucks do wear things out faster. When I drove a Ram I saw a lot of front end issues on Ram forums from Cummins owners, but only once in a while from Hemi owners. That extra 800-1000lbs really make a difference.
I’d bet city driving and parking is the leading cause of front end wear. Cranking the wheel full lock to lock without moving creates a lot of stress and wear, and that’s exactly what you see if you watch people try to fit these big trucks into tight spaces.
We have two Ram HD trucks and their front ends are junk. Having said that my '12 6.7PSD with 255k miles has all original suspension parts except the passenger side bearing and shocks. My truck did experience DW a couple of times when I had my second set of tires BF Goodrich AT when the tires were about at the end of life with ~80k miles on my truck. Never bought those tires again and never had a DW experience since then. Also had a 05 6.0PSD till about 180k miles and never experienced DW.
Although solid axle trucks have experienced DW it appears its' more prevalent with the '17 and up Super Duty's most likely using cheap parts
Here's a '17 with a 6.2 gas that's got the DW so gas powered trucks are not exempt from this problem
