If I were to use a tent I think I'd have it open both ends to clear the dust from the blasting, I'll have to rely on my mask to take care of the dust..no tent so will be doing it open air..
Good day Steve, wash the pickup and car this morning then mowed the lawn. Garden tractor needs some new belts so my wife ordered them off Amazon so that will need to be fixed before I can cut the lawn again. Then I siphoned 5 more gallons of gas out of the panel and put it in the pickup, gas is 2 years old and don't want to leave it any longer in the panel so will put some fresh gas and stabilizer and give it a run down the highway some day before the weather turns bad..
Good evening John.. Semi busy night at work.. I have a couple pallets I need to get out of the Flex tomorrow.. I have a project I need to get busy with before the 24th..
What does the project involve, I was removing the mowing deck off the garden tractor, sure has enough to remove in order to drop it..
Where's that go..? Garage or do you have a garden shed.. I'd like to build a new garden shed but material is so expensive now I'm hold off as long as I can. Might be cheaper to by a short sea can..
