Steering Wheel Controls
Old Dec 31, 2022 | 07:48 PM
Voltman's Avatar
Voltman
3rd Gear
My 2017 F250 has intermittent times that the steering wheel buttons either don't work at all or they do things that they are not supposed to do. I have a 2020 F250 steering wheel lying around the shop. Does anyone know if I can just swap steering wheels to see if the problem in in the wheel buttons?
Old Dec 31, 2022 | 08:34 PM
chadstickpoindexter's Avatar
chadstickpoindexter
It may be the clock spring going out. I had to have mine switched already on my 22. My buttons still worked but it was making a noise when turning the wheel in old weather.
Old Dec 31, 2022 | 11:27 PM
cpobst's Avatar
cpobst
If it's the same layout it should work just fine.
Old Jan 1, 2023 | 04:23 AM
NedFletcher's Avatar
NedFletcher
In the process of installing a raptor wheel on my 21, and then back to stock and onto my 22, and then back to stock waiting for my 22 6.7. For fun i also picked up a 21 lariate leather wheel and put it on the 16 f150 i sold to a friend. All the wheels are compatible, but you might want to swap the controls over from your current wheel depending on the features.
Old Jan 1, 2023 | 09:41 AM
morehouse7's Avatar
morehouse7
X2 for the clock spring. Relatively cheap part and likely the issue you are describing.
scagigal713
Feb 19, 2018 02:19 PM
Restlesswildman
Oct 6, 2013 02:20 PM
skyoung
Nov 8, 2011 07:57 PM
