1967 F100 352 distributor timing plug placement question
Old 12-29-2022, 04:57 PM
Rocktroll's Avatar
Rocktroll
Rocktroll is offline
Hi all. Need a double check before I crank, again. Need to make sure my plug wires are placed correctly. Would appreciate feedback. TY
FO is 15426378
Pertronix Dist
Rolled it to (close to) TDC.
TDC?
Rotor pointed at #1. Oil pump lined up.
Number 1 plugin center. 3rd from right screw. Got this position off a Ford thread for the 352.
Old 12-29-2022, 09:32 PM
SwampRattFord's Avatar
SwampRattFord
SwampRattFord is offline
#1 is passenger side front of the engine. Your pic doesn’t look like the rotor is pointing at #1.
FE motor diagram.
Old 12-29-2022, 10:00 PM
Rocktroll's Avatar
Rocktroll
FE motor diagram.
TY. I have seen this one also. I have rotated the engine so many times trying to get close to pointing directly at #1. I have used the 'blow your finger out' method and have it now right at that point topped out. I have a new CVF balancer on it and they say on the harmonic balancer 0 TDC. I cant get any better than this. :-(
Better pic below.
Old 12-30-2022, 09:08 AM
dubya TF's Avatar
dubya TF
dubya TF is offline
Also remember that it's a counter-clockwise rotating distributor so lead your rotor into #1 just skosh.
Old 12-30-2022, 02:42 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Thunderkiss1965 is offline
FE motor diagram.
My number one is where number six is in that illustration.
OP, it doesn't really matter where number one is, as long as it is where the rotor points one TDC #1 compression stroke. So looks good to me, does it fire?
Old 12-30-2022, 07:23 PM
Rocktroll's Avatar
Rocktroll
Yes it did Dirty Dan! She hit on first crank! Sounded wonderful! Fresh 352 sang a beautiful song! And shook the house which is a plus! lol
Jsupreme
09-14-2022 06:51 AM
Tony Ricci
05-21-2022 10:06 AM
IdFord
04-27-2021 06:40 AM
Binnacle-ZA
16
08-29-2010 03:15 AM
76BigBlock
21
05-15-2010 01:22 PM
Quick Reply: 1967 F100 352 distributor timing plug placement question
