Engine swaps
Old Nov 13, 2003 | 06:59 PM
uxhryo's Avatar
uxhryo
Engine swaps
I just bought a 78 f-250. i have a 351w to put into it. i'm new at this stuff and just wanted some general suggestions with getting it to run the best it can.
Old Nov 13, 2003 | 07:45 PM
jwtaylor's Avatar
jwtaylor
New filter, pcv valve, cap /rotor, wires, fuel filter, plugs, and bump the timing just a bit, change tranny fluid/filter, and it should serve you well. With a stock carb you pretty much just run it till it goes.
Or were you looking for ideas on making it run better, as in, faster/stronger? Either way good luck with it
