Cold weather issue
Old Dec 22, 2022 | 12:34 PM
Flatland1's Avatar
Flatland1
Cold weather issue
I just got a call from my brother, he has got a 2018 F 250, with the 6.7. It's around -5 where he is at. He said his truck started fine and ran well on his way to work, only a few miles, but when he went to go home he got a low fuel pressure warning, and truck is in limp mode. Says he has about a 1/4 tank of fuel, no anti gel..........I told him to fill it up, and put some anti gel in it......any ideas? Gelled fuel?
Old Dec 22, 2022 | 12:54 PM
Rich1961's Avatar
Rich1961
Gelled fuel. Get some treated fuel in there, and change the fuel filters.
Old Dec 22, 2022 | 01:03 PM
ToMang07's Avatar
ToMang07
Well, since he's from the future probably gonna be hard to help him.
I'd start with some Diesel 911 and some anti-gel, followed up by fresh fuel and new fuel filters, checking them for metal.
Old Dec 22, 2022 | 01:22 PM
senix's Avatar
senix
fresh fuel and anti gel. I would stay away from diesel 911 if possible.
Old Dec 22, 2022 | 01:23 PM
Overkill2's Avatar
Overkill2
Definitely gelled fuel... only thing I use is K100D+.
He should probably change the filters with a set of Motorcraft fuel filters and use some additive.
Just bringing up what I use... there's plenty other choices of anti gel additives.
Old Dec 22, 2022 | 01:46 PM
Flatland1's Avatar
Flatland1
I just talked with him. Fresh fuel, anti gel, and idling in the driveway, and the warnings went away.
I told him to get the fuel filters changed asap..........thanks........for the advice
Old Dec 22, 2022 | 02:49 PM
Overkill2's Avatar
Overkill2
Good to hear...
But I guess if it's running without a low fuel pressure warning, it might be set...
Old Dec 22, 2022 | 05:41 PM
Painted Horse's Avatar
Painted Horse
If he is running OK. The fuel will warm and as it loops around it will thaw the filters.
Usually changing the filters is because they are gelled up and nothing will pass thru them,
Your diesel fuel is heated as it passes over the engine on the way to the injectors. If the injectors don't use the fuel. It returns to the tank, ( warming the fuel in the tank)
So gelling up is usually a problem of trucks being turned off and sitting in the cold. If the engine is running and the fuel is circulating, You don't have as great of risk of gelling.
Old Dec 23, 2022 | 09:57 AM
HRTKD's Avatar
HRTKD
For my own clarity, the heating of the diesel fuel is passive, only because the lines and upper fuel filter are next to the engine, right? There's no active heating?
If the above is true, It seems like it could take a good while for the engine to get hot enough to warm the fuel.
Old Dec 23, 2022 | 11:31 AM
power15's Avatar
power15
2028?? Better read what you sent.
Old Dec 23, 2022 | 12:00 PM
HRTKD's Avatar
HRTKD
For anyone reading this, Diesel #1 has a lower gel point than #2. It's more expensive and the MPG isn't as good, but better to have an engine that runs than one that doesn't. #2 is gelled at ~17°F. I can't find the gel point of #1, but it's probably similar to kerosene (just a guess). I wouldn't run #1 for very long, just when you need it (it's going to be cold and you can't find an anti-gel additive).
Old Dec 23, 2022 | 01:37 PM
Flatland1's Avatar
Flatland1
fixed it........
Old Dec 23, 2022 | 02:37 PM
helifixer's Avatar
helifixer
#1 diesel, kerosene and jet A are all the same. just different filtering ratings from the processor.
Old Dec 23, 2022 | 02:40 PM
helifixer's Avatar
helifixer
shamelessly copied from Exxonmobile,
Jet A, which is mainly used in the United States, must have a freeze point of minus 40ºC or below and does not typically contain static dissipator additive. Jet A-1 must have a freeze point of minus 47ºC or below and for locations outside the United States, this fuel normally contains static dissipator additive. There are other key differences between the manufacturing specification within the United States and Europe/Africa/Middle East/Australasia.
Old Dec 23, 2022 | 02:45 PM
HRTKD's Avatar
HRTKD
I looked up the gel point for kerosene. -40°F!! Dang, that's low. Then again, there's a lot of wax in diesel #2.
