Need a diagnosis
Old Dec 17, 2022 | 04:27 PM
robbyfowler6's Avatar
robbyfowler6
Need a diagnosis
Having a problem. My 83 f150 runs fine when I’m up to about 40 mph. But as soon as I take it up to 55ish, the engine starts making more of a clicking sound rather than a low grumble. The first time this problem came up, I heard it making the sound I described. And the engine overheated. Since then, I have made sure to put in more coolant and ensure that the coolant level was fine. Even though, it still makes this sound when I get up past 45ish. I’m not exactly a sophisticated mechanic, so I need a diagnosis here
Old Dec 17, 2022 | 07:04 PM
85e150's Avatar
85e150
I moved you into the general part of this forum.
What engine do you have?
When it overheated, did you find the problem? Do you have a slow coolant leak, or does coolant just disappear?
Is this engine running on all cylinders?
This could be a head gasket.
These things usually don't get better and the sooner it's fixed, the better chance you'll save the engine.
Old Dec 18, 2022 | 11:13 AM
robbyfowler6
The engine is a 5.8L
As far as I can tell no coolant leaks
It makes sort of a clicking sound, and it started after it overheated
Old Dec 18, 2022 | 11:52 AM
Franklin2's Avatar
Franklin2
If it runs fine otherwise, you may have just "cooked" some of the oil in the engine and one of the lifters is sticking, making the ticking noise. You can buy a can of Rislone and add it to the engine oil and drive it a month or two and see if that takes care of it. There are a lot of detergents in the Rislone and that can loosen stuff up inside the engine.
BassFantasizer
2015 + Expedition & Navigator
Dec 18, 2022 06:38 PM
reggiedunlop
Oct 27, 2019 01:58 PM
mattthegreat
May 21, 2011 11:03 AM
TXBDBY
Nov 24, 2006 06:15 PM
pYmpdaddi
Feb 4, 2003 12:50 PM
