1999 Low Power until 2500 RPMs Hard/No Starting when cold
Here's what we have tested or symptoms we've noted:
- Fuel Pressure is above 50 psi at idle and under load
- NO black smoke WOT acceleration
- HPOP pressure at 650 at idle
- Injectors
- Glow Plugs
- PCM
- HPOP
- ICP sensor
- IPR valve
The following users liked this post:
Originally Posted by Kwikkordead
Map sensor failed? Boost pressure sensor pipe clogged, and/or the sensor bad?
Originally Posted by nicksorenson
Going to check that first. Very well could be.
Ok, to update this thread with some MAP sensor numbers.
I have 5V coming into the MAP sensor on Pin 1, However, on pin 2, I have only 0.4V from idle to 1500 RPMs without any changes. So I'm guessing either it's receiving no boost or the sensor is bad. I suppose I could T in a pressure gauge to the hose feeding the MAP to check for boost, or just replace the sensor and see what happens.
Could the problem be wastegate actuator (or maybe the control solenoid) related?
Recommend watching MAP on FORScan through the OBDII port. Cheap and effective diagnostic tool - you can check several sensors and get an idea of where things are. Link below:
https://www.ford-trucks.com/forums/1...d-q-and-a.html
I have disconnected the turbo air charge hose from the MAF sensor and applied air pressure with a compressor and the voltage does indeed change at the center pin, so it's working as it should. I next wondered if maybe the PCM isn't receiving the signal so I connected to the truck with Torque Plus on Android and can see that the signal also changes with the air pressure we applied.
One other thing we noticed is that there is a miss at certain RPMs. Is there anything I should look for related to that?
