Well, I can at least tell you the setup on my 84 with a 351, so it is most likely a little diffrent. On mine, a thick rubber hose comes off the pump into a "T" configuration. One part of the "T" goes to a steel air pipe that bolts to the back of each head. The other part of the "T" has the steel pipe clamped to it that runs down to the cat. The "T" itself has what may be a solenoid-type valve on it. This gets hooked up, I think, to a vaccuum source (that's at least what I did with mine when I replaced the engine). So to answer your question, you may need to find out if the 300 had a "blowhole" in the back of the head like a 351. If it doesn't, I don't see why plumbing the pump right up to the cat won't work. Is this to pass emissions or just to "show" that your pollution control junk is in place?
-Tom
Originally posted by hflu Well, I can at least tell you the setup on my 84 with a 351, so it is most likely a little diffrent. On mine, a thick rubber hose comes off the pump into a "T" configuration. One part of the "T" goes to a steel air pipe that bolts to the back of each head. The other part of the "T" has the steel pipe clamped to it that runs down to the cat. The "T" itself has what may be a solenoid-type valve on it. This gets hooked up, I think, to a vaccuum source (that's at least what I did with mine when I replaced the engine). So to answer your question, you may need to find out if the 300 had a "blowhole" in the back of the head like a 351. If it doesn't, I don't see why plumbing the pump right up to the cat won't work. Is this to pass emissions or just to "show" that your pollution control junk is in place?
-Tom
I just put a cat on this truck, it hasn't had one for years, and I am wanting to get the air supply hooked up to it. It doesn't have to pass an e-check. I just got tired of the exhaust stinking.
