Forscan second reprogramming
Old Dec 10, 2022 | 04:40 PM
BrentSp's Avatar
BrentSp
4wd Low
I had the tailgate popping open on its own recall issue fixed but they played with the BCM and now my doors lock automatically when I start to drive my 2019 f250. I had disabled it years ago with the forscan but now I can’t remember how I did it.
Also my DRL would come on when I put the truck in drive and now they don’t and my signal lights hyper flash because I did an led upgrade.
I have read the forscan BdyCM AS BUILT and Module configuration and can’t figure out how I did it before.
Can any one please help?
Old Dec 10, 2022 | 05:36 PM
4wd6.7L's Avatar
4wd6.7L
The doors auto locking is selectable in the dash menu. No forscan needed.
Do you have the headlight switch all the way the the right when putting it in drive?
Old Dec 11, 2022 | 02:43 PM
BrentSp's Avatar
BrentSp
4wd Low
Wow! thanks 4wd6.7L… You got the door locks!
I had it set up so the tail lights would com on with the head lights when you put the truck in drive with out having to turn on any lights.
Old Dec 11, 2022 | 05:55 PM
cficare's Avatar
cficare
FWIW, when I had the tailgate recall performed on my 2017, none of my Forscan changes were altered by the dealer.
Old Dec 11, 2022 | 06:02 PM
4wd6.7L's Avatar
4wd6.7L
He might have had the updated "fix" which I think does include some BCM reprogramming. I never had the tailgate recall done but did have the DRL recall completed. After that some of my Forscan changes, the changes in that particular module (BCM), had to be re-done.
Old Dec 14, 2022 | 08:57 AM
BrentSp's Avatar
BrentSp
4wd Low
It was the second recall because the fist one did not work. The BCM is listed in the work order and its now a double click to open it. I have had to reprogram a few different things. Still struggling with the Auto tail lights and the hyper flashing led signal lights.
Old Dec 14, 2022 | 09:13 AM
Gomerpyle's Avatar
Gomerpyle
When I made forscan changes to my truck, I made a log of every change I made and what the factory setting was, that way if it ever goes to dealer & they make changes, I can always go back in & know exactly what to look for and where. It may not be necessary, but I have it if needed.
Old Dec 20, 2022 | 06:58 PM
BrentSp's Avatar
BrentSp
4wd Low
Yes This is good advice!
rayjobob
Jun 6, 2018 08:37 AM
BigSpenda864
Feb 2, 2018 09:29 PM
Dorito
Texas Chapter
50
Mar 4, 2013 03:02 AM
F3r5e0d
2004 - 2008 F150
Apr 24, 2011 10:01 PM
arninetyes
1997 - 2003 F150
22
Jun 1, 2006 03:15 AM
