Connector 270D identification
Old Dec 9, 2022 | 05:33 PM
Mr. Obvious's Avatar
Mr. Obvious
Hi,
Having a starting issue with the 2003 expedition XLT and need to identify connector C270D on the fuse box in the right side kick panel. This connector is not identified in the service manual wiring diagram I have. I have no continuity between the starter relay pin socket 87 and the solenoid wire at the solenoid. I am not sure which connector on the fuse box this runs through.
Thank you.
Old Dec 9, 2022 | 09:17 PM
Hamfisted's Avatar
Hamfisted
Can you follow the Yellow / Lt Blue wire ? If you apply 12v to it does the starter engage ? I attached the starter circuit wiring diagram from the factory service wiring manual in case it helps.
Old Dec 10, 2022 | 06:57 AM
alloro's Avatar
alloro
Originally Posted by Mr. Obvious
Hi,
Connector face and location map attached.
Old Dec 10, 2022 | 05:59 PM
Mr. Obvious
Figured it out
Thanks for the help. While looking at it again today I found a chewed through solenoid wire above the air conditioning compressor.
Squirrel got to it while I was away for a week.
Thanks again for the help!
Scout
Nov 5, 2024 09:38 AM
75Three90
Jul 8, 2022 04:22 PM
bbender85
2004 - 2008 F150
13
Apr 24, 2021 07:38 PM
tjc transport
Electrical Systems/Wiring
Sep 23, 2018 04:16 PM
snifferpro
All Things Towing
May 10, 2017 10:40 AM
