Water Leak - HELP!
Old Dec 7, 2022 | 08:35 PM
Kustrud's Avatar
Kustrud
Water Leak - HELP!
I’ve read numerous forums/posts and I can’t figure this out.
Also, it is NOT my third brake light. Taken it off twice after rain and dry as a bone and gasket is sealing perfectly!
After a rain I noticed stained headliner on driver side rear corner of cab. Went out during downpour and sat in truck, water was slowly dripping from the very bottom/back of the headliner onto the driver side rear seat headrest. Carpet in entire truck is dry, the headrest seems to soak the majority up at least lol! Where else are common leaks back here? I’m OCD about keeping my truck perfect and this is absolutely killing me!
Old Dec 7, 2022 | 08:40 PM
mattymax's Avatar
mattymax
What year ?
2020 and above have the antennas in the back on both sides which may be causing the issue
Other than that, check the body seems back there
Old Dec 7, 2022 | 08:47 PM
KU4OJ's Avatar
KU4OJ
Also which cab, and what other things do you have that make holes in the roof, such as sunroof, cab marker lights, so on?
Old Dec 7, 2022 | 08:56 PM
Johnny F2 fiddy's Avatar
Johnny F2 fiddy
When one of the corners (front left) of my 2015 sunroof got clogged, it ran out the seam in the A-pillar about halfway up the window.
Old Dec 7, 2022 | 10:03 PM
Kustrud's Avatar
Kustrud
Dang it sorry, meant to put that!
2017. No sunroof and no sliding back glass!
Old Dec 7, 2022 | 10:06 PM
4wd6.7L's Avatar
4wd6.7L
Like mattymax posted, could be the body seam under the plastic trim.
Old Dec 8, 2022 | 05:33 AM
Kustrud's Avatar
Kustrud
If it is that, how do you fix??
Old Dec 8, 2022 | 06:34 AM
Pugga's Avatar
Pugga
2017, did it just start randomly? I'd at least try to get the headliner down in that corner so you can see what's going on. With the headliner out of the way, you should be able to get an idea of how the water is getting in. If it's a body seam, I'd clean it up and use a sealant, just make sure you don't gob it on, create a water dam and force a new problem somewhere else.
Old Dec 8, 2022 | 08:00 AM
#1bigmark's Avatar
#1bigmark
Temporarily Deactivated
I’ve seen so many threads regarding water intrusion on the SD trucks. Is it happening to the F150 too?
I haven’t had a truck leak since my 84 F150 with the legendary 300 6.
Old Dec 8, 2022 | 09:36 AM
Kustrud's Avatar
Kustrud
I just held a hose all over the back. Top of cab trim, brake light, around windows, etc. for a good while.
Not a damn drop! What gives!?!?
Old Dec 8, 2022 | 09:53 AM
redford's Avatar
redford
FTE Leadership Emeritus
Body seam sealer.
There are many brands and styles. Here is one at WalMart. Just listing an example, not recommending anything.
https://www.walmart.com/ip/Black-Fas...d20a&gclsrc=ds
Old Dec 8, 2022 | 11:50 AM
cficare's Avatar
cficare
Do you have cab lights? Those lights were later updated with thicker gaskets.
Old Dec 8, 2022 | 03:37 PM
Kustrud's Avatar
Kustrud
No cab lights.
Old Dec 8, 2022 | 09:04 PM
morehouse7's Avatar
morehouse7
Originally Posted by redford
Body seam sealer.
Old Dec 8, 2022 | 10:26 PM
Mack3006's Avatar
Mack3006
My 2017 f250 XLT ccsb started doing this about 2/3 months ago. Kept noticing everything under the back seat was wet on the driver side. Passenger rear corner had a tiny bit of water inside. Driver had a lot.
during a rain storm I went out and watched it dripped.
from what I could tell it was the window seal. There was room on the outside of the cab between the window and the cab aluminum. I confirmed it was not the third brake light.
I had the truck almost 5 years before this happened.
