New 460
Old Dec 4, 2022 | 05:48 PM
Lnk's Avatar
Lnk
New 460
So I just changed head gaskets in my 95 f250, 460 5 speed. All went well until white smoke started coming out of the exhaust. I did not take the heads to have them checked before reinstalling. Runs really good, idles at 650-700 rpm, but the white smoke doesn't stop.
My question, where to source a replacement? There are rebuilders that will send you an engine and you send back the core. Really don't know whether it is a gasket or cracked head/engine. Seeking the advice of this forum. Just want a stock truck, nothing crazy. I looked online for used and nothing advertised. Do I pull it and send for a rebuild or get a rebuilt long block?
Thanks,
Larry
Old Dec 4, 2022 | 09:38 PM
88n94's Avatar
88n94
Are you actually losing coolant or does the exhaust smell sweet? If the weather is just right with moisture in the air white smoke is normal. Just a thought. Yes I see you are in Tennessee.
Old Dec 5, 2022 | 05:18 AM
Lnk's Avatar
Lnk
Both actually, exhaust is sweet, and I am losing coolant. Getting puffs of steam out the breather on the driver side valve cover also. I am going to have to pull it.
Old Dec 5, 2022 | 06:30 AM
arse_sidewards's Avatar
arse_sidewards
Check the heads next time you have them off. $10 for a feeler gauge and $30 for a sufficiently accurate level.
Old Dec 5, 2022 | 05:36 PM
kevinv10's Avatar
kevinv10
My first question is why did you change the head gaskets? If the lower end is in good shape, I would pull the heads and get a good machine shop to look at them. Would be cheaper than a new engine. If heads are good I would take a solid metal level, put it across the block, and use a feeler gauge to see if the block is warped. But, I would bet its your heads.
Old Dec 5, 2022 | 06:22 PM
Lnk's Avatar
Lnk
When I pulled the heads, the evidence showed a blown head gasket. I will tear it down again and check the block deck and check the heads for flatness. I should have done that, but I found the thermostat upside down and figured the PO had caused the blown head gasket. I have not had the truck in the road as I detected white smoke when I traded for the truck. I still think I am ahead as I traded an '02 Honda Civic with 170k on it. I bought the civic for 2k 6 years ago for my daughter, who bought another car.
I am just a little despondent that I did not do my due diligence on this repair. Frustration is making me take a short break to think on my next course of action. Thanks for the support.
Larry
Old Dec 6, 2022 | 07:11 AM
arse_sidewards
You'd do well to think about the difference between blew head gasket and then overheated vs overheated and then blew head gasket.
Old Dec 6, 2022 | 04:59 PM
Lnk's Avatar
Lnk
Please enlighten me as to the difference. Maybe I am thick! Really would like to know what you are getting at.
Old Dec 6, 2022 | 05:53 PM
arse_sidewards
Heads aren't a uniform log of metal so they want to turn into weird shapes as they heat/cool. Over a narrow 300deg rainge (say -50 to 250) this is fine, the bolts will hold them straight (enough) and they'll get back to normal after each cycle.
If the gasket blows (usually from age/wear, the head to block interface moves around a tiny bit during normal operation which wears out fiber gaskets over hundreds of thousands of miles) and then it overheats your heads are probably fine (unless you really run it with the gauge pegged).
If you overheat an engine with a serviceable head gasket so much that the gasket blows the heads are probably warped because how else would the head gasket have popped. You had to have gotten it so hot that the heads were warped enough to be trying to lift themselves off the block hard enough to make the gasket fail in which case they're probably permanently warped a few thousandths.
scottyd9
Jun 13, 2022 12:13 PM
RamdyZavage
Apr 10, 2018 07:54 PM
NinthGenF-SeriesOBS
Oct 12, 2016 05:22 AM
jwmayfield
Sep 13, 2011 11:21 PM
bigtoe
Aug 8, 2002 11:40 AM
